'Will I die?&#...
[Closed] 'Will I die?' content.... (BB related)
[#6690550]
Well, yes ultimately I will...
However in the shorter term; what will happen if I remove the drive side spacer from my XT crank/BB combo? By removing it, I'll get a much better chainline on the 11 speed setup I've put on the rear... It's a bit 'grindy' in 1st gear at the mo 🙁
But.... what, dear forum, are the consequences?!?
Posted : 08/12/2014 10:06 am
If you pop it on the non-drive side it should be fine, assuming you don't have two there already.
Posted : 08/12/2014 10:09 am
yeah, it's a 73mm BB, so just one on the d/s....
so, that'll do the trick then?... hmmm, seems logical
Posted : 08/12/2014 10:12 am
I'm thinking about doing this too, but having never fitted a BB I do not know where the spacer is. Do I need to remove the BB cups to get at it?
Posted : 08/12/2014 11:26 am
Yes.
Posted : 08/12/2014 11:35 am
Cheers!
Posted : 08/12/2014 11:39 am
