Will GRX hydro leve...
[Closed] Will GRX hydro levers work with Slx XT calipers?
[#11424460]
I need more braking power, 160mm rotors snd sintered pads just aren’t quite enough I recognise it might require a new fork etc. But could you pair a MTB caliper with the GRX levers?
Thanks!
Posted : 11/10/2020 8:55 pm
I believe all the Shimano 2 piston calipers push the same oil volume.
The Hope RX4 caliper might be easier/cheaper than a new fork.
Clark also make a 160FM-180FM adaptor if your forks are up to it.
Posted : 11/10/2020 8:57 pm
Is there not a mineral oil / DOT5.1 compatibility problem with mating a shimano lever with a Hope caliper?
Was looking at this as a possible fix for my current banshee shimano brakes on my cross bike but thought this would be a problem.
Posted : 11/10/2020 9:55 pm
Hope do 2 rx4 mineral oil & DOT 5.1 compatible calipers
Posted : 11/10/2020 10:02 pm
They actually do 4 - post mount & flat mount for both dot & mineral oil
Posted : 11/10/2020 10:05 pm
Specific RX4s are designed for mineral oil.
If you need more power, switch to organic pads .
Posted : 11/10/2020 10:27 pm
Three - they don't do mineral post mount now. Or so I was told.
I've got GRX 400 levers paired with Zee brakes on my gravel bike and they work just fine. You may need to get new front and rear mechs...
Posted : 11/10/2020 10:31 pm
I use xt m8000 calipers with some Di2 road levers. Those shifters are a few years old. This set up works a lot better than with r785 calipers.
Three – they don’t do mineral post mount now. Or so I was told.
Well they're still available to order on the Hope B2B so I guess you were told wrong.
Posted : 11/10/2020 10:43 pm
Nice one cheers all. I’ll see what the girl can take! Seems daft that GRX only do 160mm. Hope don't do a suitable calaper 😕
Posted : 11/10/2020 10:48 pm
