Will a low stack st...
[Closed] Will a low stack stem work with this?
Just put some Fox 34 on my bike and realised the steerer is a bit short, by about 10-15mm.
It has a Hope AM stem fitted at the moment, can anyone recommend a low stack stem which would be suitable?
[url= https://preview.ibb.co/gV34nk/IMG_4066.jp g" target="_blank">https://preview.ibb.co/gV34nk/IMG_4066.jp g"/> [/img][/url]
[url= https://imgbb.com/ ]web img[/url]
Posted : 15/06/2017 4:34 pm
Ragley Stubbing stem is 10mm shorter than a Hope. That should get you close enough. Looks more like 10mm than 15mm in your photo but measuring it might actually help.
Posted : 15/06/2017 4:42 pm
Posted : 15/06/2017 4:43 pm
You need one of those Sunline (think that's the name) stems.
I bought one for the same reason. Pretty cheap from memory too.
Pretty sue it's the same stem as the Ragley mentioned above. Rebranded and cheaper. I think!
Posted : 15/06/2017 4:46 pm
Thanks. Do you have a link to the Sunline stem?
Posted : 15/06/2017 5:03 pm
Someone selling a Sunlime stem in classifieds. Hold on...
Posted : 15/06/2017 5:05 pm
 st
Look for a Funn Funnduro. They have a 30mm stack height and have sorted my short steerer issues out a couple of times.
They are getting a bit harder to find but a couple of minutes searching should sort it.
[url= http://singletrackworld.com/forum/topic/dropper-posts-50mm-stem ]here[/url]
I'm not the seller, nor do I know him. Just happened to see the ad.
Ask seller to confirm the attack height. I "think" this is one of the models they did that has a small SH...
Posted : 15/06/2017 5:06 pm
Stack height of a Sunline V1 is quoted as 35mm. That's about 3mm taller than the Ragley
Posted : 15/06/2017 5:10 pm
scotroutes - Member
Indeed it is mate. 🙂
Posted : 15/06/2017 5:13 pm
dmr stem is 27mm stack I recall.
Posted : 15/06/2017 5:31 pm
Most of the stems mentioned will do the job, do the reserach yourself rather than take people's words on the measurements though.
You can get away with more of a gap than you might think, 5mm is totally fine and you don't really want it too close to the top TBH.
Posted : 15/06/2017 5:39 pm
chakaping - Member
Oi! I actually went to the garage and measured the Stubbing 🙂
Posted : 15/06/2017 5:41 pm
My cousin, vinny, would like to know what you measured it with, and whether it was correctly calibrated?
Posted : 15/06/2017 6:16 pm
DMR Defy stem, just measured at 30.5 MM. with a set of recently calibrated Verniers.
Posted : 15/06/2017 6:24 pm
As above...
Interested no one has mentioned headsets yet though. There can often be 10mm of stack saving there, too depending on type.
Posted : 15/06/2017 7:26 pm
I wasn't casting nasturtiums at anyone's measuring skills. Just aware product spec can change.
OP probably wants to keep that nice Hope headset in the pic.
Posted : 16/06/2017 9:13 am
DMR Defy as above was the shortest I found when faced with this issue.
Posted : 16/06/2017 9:22 am
Thanks guys. Just sent the lad a message about the stem above. If thats not available I will got for the DMR.
Is it necessary to have spacers fitted or can you run without them?
Posted : 17/06/2017 11:27 am
No spacers necessary. I had the exact same problem when I swapped all my bits over to a new frame recently. DMR Defy for £20 off the classifieds had me sorted.
Posted : 17/06/2017 12:11 pm
What length stem do you want? I've got a stubbing you can have for postage cost but I think it's 65mm long.
Posted : 17/06/2017 12:47 pm
65mm would be fine.
Happy to proceed if you can PM me your PayPal details? I will send a bit extra over as well 🙂
Posted : 19/06/2017 8:00 am
Just emailed you MRJMT
Posted : 19/06/2017 4:17 pm
