Wilkinson 820 29er ...
[Closed] Wilkinson 820 29er Wheel - Or best dirt cheap alternative?
Hi Guys
My last effort was named incorrectly so lets see if anyone knows anything about these wheels.
http://www.edinburghbicycle.com/products/wilkinson-29er-820-alloy-wheel
I'm going to build an experimental 69er with my scandal frame and I want a dirt cheap 29er front wheel, not having much luck in the classifieds so looking at the lower end of the new market.
Any experiences or alternatives?
Posted : 14/03/2014 9:27 am
Must add it is for off-road trail use and must be 9mm to match my rigid forks.
Thanks
Posted : 14/03/2014 9:28 am
It's a cheap wheel , but as long as you keep a check on the spoke tension it should be fine
Think the rim is a little narrow but can't reminder to be sure
Deore hub is mother special either but if looked after will last ok
There does not seem much choice for cheap ready build 29er wheels
Posted : 14/03/2014 9:34 am
Cheers,
There certainly is a lack of options as you say, cant seem to find the rim width anywhere which is a spec worth knowing really.
Posted : 14/03/2014 10:34 am
If you are looking for something to run a big tyre I may be able to help you. email in profile.
Posted : 14/03/2014 11:07 am
