Not sure I can be faffed with swapping the freehub to steel for a winter of ss. I have a wide base ss sprocket....
Do folk find they are OK on alu freehub?
Cheers, Chris
Yes
Any deals about.. was looking for one
They're fine.
On one groove armada normally fairly cheap.
To expand, I use an on-one wide base cog (I forget its name) on a Hope alloy freehub and it doesn't dig in or gouge or anything.
Edit - aye, that's it - Groove Armada.
Andel something or other stainless one from velosolo is pretty good. Or Surly.
Magic, thanks folks
Gusset Double SIx - 7mm wide base, available in wide range of sizes and around £12.
Used them for years and they wear very well.
I have seen even wide based cogs chew through alloy freehub bodies.
As it turns out, changing the axle adaptors meant the freehub was a doddle to replace for the steel one... So I did.
Now if only I could find the 135x10 qr to go with.....
