Whyte 146 Rear Tyre...
[Closed] Whyte 146 Rear Tyre Suggestions Please
Hi,
I've got a Whyte 146 Works which came with a Maxxis Ardent on the front and a Maxxis CrossMark on the rear. I appreciate the rear tyre is a faster rolling racing tyre and on the trails I certainly have no complaints! However, riding cross country is a different story (I know it's not a XC bike). Can anyone suggest a suitable all weather all rounder (preferably puncture resistant) combo?
Posted : 24/01/2012 2:49 pm
What about a maxxis high roller.
I quite like maxxis tyres, but then i use that combo on my 805 and it works very well, i run 50psi too. All my riding is xc, red route trail stuff.
Posted : 24/01/2012 3:01 pm
Are you losing rear end grip on climbs or do you just want more grip everywhere? Are you willing to add a bit of weight?
Posted : 24/01/2012 3:22 pm
It depends on your priorities...
Quad Link 2 bikes are a little sensitive to tyre choice, there's a tradeoff between traction, drag and wallow to take into account. I've got a Wolf Ridge which has avery similar setup to the Whyte.
On the back of the bike I've tried Nevegals, Small Block Eights, Ardents and High Rollers. I found with SB8s and Ardents that the bike spat traction abruptly which made climbing a bit of a mission. The SB8 also has some bad manners under braking too, unlike the Ardent which was pretty stable aside from climbing in the wet. In fact, I'd suggest that Ardents are the ideal dry weather rear tyre for your bike.
The Nevegals gave fantastic grip and traction, but at the expense of rolling resistance which made epic rides an absolute chore, however whislt riding the downhills in North Wales the bike felt unbelievably stable and fast to boot. The High Roller was better here, but I didn't get on with the loss of any feedback or grip at intermediate speed. It's an all or nothing tyre.
Posted : 24/01/2012 3:57 pm
PJM1974
As opposed to bikes that aren't sensitive to tyre choice, exercise bikes maybe?
For mixed muddy terrain and reasonable rolling resistance look at specialized storm controls or maxxis medusa. For constant deep mud panaraced trailraker, for tons of grip but compromised rr look at schwalbe muddy marys and super tacky high rollers.
Whatever you choose it'll be some sort of compromise and you'll not know what works for you until you try them so get buying!
Posted : 24/01/2012 4:33 pm
Stevewhyte try dropping your psi to about 30-35psi MAX off road it'll be MUCH faster as it'll roll smoothly over thing instead of being deflected away from them .
The only time 50psi would be faster is on the road .
Posted : 24/01/2012 5:01 pm
@jimjam
Try riding a Quad Link 2 bike and an FSR back to back and you'll see exactly what I mean.
An FSR has better traction, at the expense of pedalling support so you can get away with shallower treaded tyres because the suspension doesn't ramp up and cause the traction to spit suddenly.
You're more than welcome to try mine if you like.
@Whyte1 is quite right here too.
Posted : 24/01/2012 8:12 pm
I ditched the Crossmark for an Aspen 2.25 which I found much better. Running Bonty XR4s at the moment tho. Seem to suit the bike really well and fantastic winter grip.
Posted : 24/01/2012 8:55 pm
PJM1974
I used to work in a Marin/Whyte dealership and own an FSR. I choose tyres based on trail conditions.
Posted : 24/01/2012 9:24 pm
 gb1m
I also ditched the crossmark on my 146 and replaced with aspen as well but it only lasted a couple of rides until a rock slashed the side.
Replaced with ardent exo on rear and for the shit conditions at the mo have put a 2.5 minion on the front. Seems a good combination if a little slow on tarmac, but hey , it helps with my belly.
Posted : 24/01/2012 9:43 pm
My 146S also came with said tyres - unless it's bone dry they are utterly awful...I am now running some Conti Rubber Queen's 2.2...seem to be far better.
The High Rollers I had on the Mount Vision were the 2.1 versions and they were also truly awful...the much bigger volume 2.3 or 2.4 version are far better.
Posted : 24/01/2012 9:50 pm
Maxxis ADvantage are a superb tyre, even in the 70A compound.
Posted : 24/01/2012 9:58 pm
Whyte1 - Member
May be if you are 10 stone but not 15. I dont like running much less than 50psi, maybe run 45psi front 50 psi rear.
I would rather avoid punctures running slightly higher pressures than get a pinch every ride.
p.s. I run 100psi on the road btw. ๐Ÿ˜€
Posted : 24/01/2012 10:26 pm
Tubeless is the future , punctures are just a horrible memory
Posted : 24/01/2012 10:52 pm
Sorry i dont buy into the tubeless thang.
Posted : 24/01/2012 11:00 pm
You should, it's great. Buuuut, doesn't mean you can run drastically lower pressure anyway, since if you were pinching, you'll still be banging the rims- drop the pressure and you just swap pinches for dents ๐Ÿ˜‰
Doubt anyone else will recommend this, it's my "what tyres for" wildcard- Kenda Telonix 2.2 DTC. God knows what it's supposed to be for, sandy soil I hear, but what it turns out to be is a little XC mud spike. Grip is flaky on woodwork and fairly low on stone, but great on anything with any give in it. And it's respectably fast rolling to boot.
Or failing that just get an Advantage, they are awesome.
Posted : 24/01/2012 11:08 pm
