who else is running...
[Closed] who else is running home made lights?
[#272362]
too tight to buy a powerful set of lights so 1 lead acid battery, 1 20watt halogen spot and a lynx can later and hey presto great light set - bn using em for 3 years & no probs easily as good as comercially avalible lights - what did you make yours from?
Posted : 03/02/2009 10:57 pm
No You cannot mention Home made lights
burn the heratic
Posted : 03/02/2009 11:05 pm
No one makes homemade lights, or has ever made them. It's just you.
Posted : 03/02/2009 11:14 pm
does buying the torches with the body extenders from dealextream count?
bought 4, shortened, driled the sides out, soldered soe wires in, hey presto, stupid levels of light 🙂
Posted : 03/02/2009 11:24 pm
Nope not home made so you are safe
the swear filter missed the word "buying"
Posted : 03/02/2009 11:27 pm
Definitely no Home-Made Lights in use here either....
Posted : 03/02/2009 11:54 pm
Check out this article on [url= http://www.mtbbritain.co.uk/mountain_bike_lights_review_led.html ]MTB Britain[/url]
I have similar Cree torches from Dealextreme 2 on the handlebars and one on the helmet.
Using handlebar clamps from cheap BLT lights with tie wrap channels cut with a dremmel and the torch tie wrapped to the mount. The helmet mount is off a specialized halogen which broke and is modified in the same way.
Cree are not as bright as the SSC P7 but get a longer run time
also got the protected 18650 Li-Ion batteries and charger
Posted : 03/02/2009 11:55 pm
only 'trout'made lights used here
Posted : 04/02/2009 12:30 am
