oem forks
[Closed] oem forks
 lord
[#272376]
oem forks any different ? thanks
Posted : 03/02/2009 11:16 pm
Colours, sometimes a bit more weight, sometimes adjustable features not present.
Posted : 03/02/2009 11:19 pm
occasionally a steel steerer instead of aluminium, sometimes a bit less external adjustability. Most are the same these days I think. I think some really cheap oem forks might be different though.
yes, usually less adjustment, not necessarily heavier.
Posted : 03/02/2009 11:20 pm
Which ones?
If they are rockshox, the OEM ones have a different number (eg 409, 335, 327, 289). If you go on the website you can compare models to see what the differences are
Posted : 03/02/2009 11:22 pm
 GW
what a wonderfully vague question, the wonderfully vague answer is "sometimes" 😉
Posted : 03/02/2009 11:24 pm
 lord
426 revelations silver
Posted : 03/02/2009 11:26 pm
426 revs are normal (non OEM) stock
409s are the OEM ones (the only difference being the floodgate (how lock out the lock out is when engaged) adjuster requires an allen key)
Posted : 03/02/2009 11:27 pm
 lord
cheers chaps.
Posted : 03/02/2009 11:33 pm
