Which Suspension se...
[Closed] Which Suspension seatpost?
[#2319441]
For a HT to do Transwales.
27.2mm seatpost diam.
Any recommendations?
Posted : 28/12/2010 8:00 pm
The USE XCR is good or the Cane Creek Thudbuster is better. Both available in 27.2 or shimed
Posted : 28/12/2010 8:05 pm
Do you think its would make a difference as had considered in a previous post to build a cheap 100-120mm FS for it?
Posted : 28/12/2010 8:08 pm
the thudbuster will make a great deal of difference.
Posted : 28/12/2010 8:10 pm
i have a thudbuster. it is brill.
Posted : 28/12/2010 8:16 pm
another vote for a thudbuster
Posted : 28/12/2010 8:23 pm
Cool - Maybe I'll save up - I just think 7 x 70 Km and my arse will be pummeled
Which one - LT or ST (3" ot 1.3.") ?
Cheers guys 🙂
Posted : 28/12/2010 8:25 pm
I have used USE posts for years on my hardtails. Simple, easy to service and work well. I would say get the long travel version of whatever you get.
Posted : 28/12/2010 9:36 pm
+1 for USE XCR.
I had this dilemma last year a few weeks before doing the kielder on my very hard scadnium voodoo.
I opted for the USE as the design allows movement vertically whereas the cane creek one moves backwards and down.
Posted : 28/12/2010 10:12 pm
probably lt. you won't be getting 3", it will mostly feel like a gentle rocking backwards/forwards.
the lt has quite a lot of setback which you might want to check on. also, it has a bit more setback than stated because it will 'sag' backwards a touch when you sit on it.
I have an XCR in the Carbon Sumo variety. Its doesn't have the travel of the thud buster, but it takes the sting out of your arse and back. I have had mine on my SS for about 4 years and it has never caused the slighhtest issue. Well worth the money on a HT.
Posted : 28/12/2010 10:17 pm
thudbuster - awesome
i do a lot of long distance riding in mid wales / lakes on rocky trails - it works superb and is easy to strip down
paul
Posted : 28/12/2010 11:04 pm
With a USE you need to ensure that your saddle is pretty much centrally mounted on your post - if you have it slid forward or back then it won't work very well.
Other than that they work well - have had two XCRs and also an SX on the commuter.
Posted : 29/12/2010 5:06 am
wow - cheers guys - than ks for the info 🙂
Posted : 29/12/2010 8:28 am
Have got a barely used USE shockpost with 27.2mm shim in the garage.
Email in profile if you want pics.
Cheers Rob
Posted : 29/12/2010 10:51 am
YGM
Posted : 29/12/2010 11:21 am
Cheers for the offers - Think I like the Cane Creek concept - but I need to save some money first for anything 🙂
Posted : 29/12/2010 11:28 am
