Which rim would you...
[Closed] Which rim would you go for?
[#2065594]
It's going to be a rear SS wheel built with Superstar SS hub, DT Comp 2-Butted spokes and... d521 or x317? I have the former but it's heavier. Will I notice? Or should I split a Hope XC/719 wheel and rebuild it onto the d521 and use the rim on the SS?
I have plenty of time, limited patience and rich swearword vocabulary in several languages. Also proper tea, coffee, biccy and ice-cream.
What would you do?
Posted : 07/10/2010 4:48 pm
What you using it for?
Xc then the 317
dh then the 521
Posted : 07/10/2010 4:50 pm
Just use the XC/719 wheel with a single speed cog and spacers.
Posted : 07/10/2010 4:51 pm
you'll notice a step from a 521 to a 317. 719's kind of between the two.
Doesn't really help.
Do you need a 521 due to ridign style/weight. If no then go for the lightest you can get away with. Unless you already have spokes - they might not work with all those rims...
I have the d521 already, brand new and unused. I fancy a rear wheel on it with gears for my 456SS (lack of skill necessitates stronger wheel). The SS will be lightweight (ti frame), but I don't have the rim for it unless I split the existing one. The ERD difference between d521 and 719 is 5mm. Will it matter?
Posted : 07/10/2010 4:53 pm
Keep the 719 wheel as it is
Sell the 521 rim
Buy a new 719 or 717 rim.
Posted : 07/10/2010 4:55 pm
Sell the 521 rim
Doable in the UK, pointless when I'm in Ireland. The 317 is way cheaper than 717 too.
Posted : 07/10/2010 5:50 pm
Hoooray! I've just found a WTB/317 wheel with a shagged freehub body. The rim is sorted. What's the length of spokes I'll need? SSC SS hub onto 317 disc rear wheel?
Posted : 07/10/2010 5:54 pm
EN521 is about 80 gm each more than 719....teh sort of weight difference that can be found between different inner tubes / tyres! So on a more genarla point if you use a heavier rim you could compensate for this in your choice of inner tube for example
Posted : 07/10/2010 6:12 pm
use the dt swiss spokey dokey calculaterorer thing (or email CRC they're normally quite good).
Posted : 07/10/2010 6:40 pm
Will probably need to. Is a difference of 2mm anything to be concerned with? Hoping to use the spokes from a toolbox instead of buying them.
Posted : 07/10/2010 6:44 pm
