Which power meter -...
[Closed] Which power meter - Stages or Power2Max?
Thanks guys. Yeah, I appreciate it will fluctuate and I probably could be smoother but sometimes even staying within a particular zone is difficult - say if its gusty.
Posted : 06/05/2015 7:49 pm
I wonder if longer has a place on a drag strip TT course, for pacing. About it.
For TT I still stick to 3 second avg, though am watching the PM a lot more and sometimes the delay is a bit annoying. Can't see 30 second being useful as you really want to make sure you are at the limit all the time. Though you do have to be careful not to end up chasing a power value.
Posted : 06/05/2015 7:57 pm
 DanW
Holding +/- 5W is never going to happen but a "zone" is what 30-50W wide? You should be able to hit that for most of a ride/ interval on RPE and is why gears were invented 😀 There also isn't anything wrong with drifting outside the "target zone" for those times when outside factors disrupt your rhythm. It is impossible to "ride to the numbers" but RPE should get you in the ballpark and the PM is a quality check. Exactly as monkeyfudger says, a quick glance as a quick check after settling into a pace rather than chasing numbers is the way to go.
Posted : 06/05/2015 10:59 pm
10s average for me, sometimes 30s. What exactly are you doing that needs such a precise measurement? Even when I do 20/40s, I'm counting seconds not watts. I'd have thought 30s was de facto for TTs. Holding +/- 5 watts is [url= http://journals.lww.com/acsm-msse/pages/articleviewer.aspx?year=2004&issue=07000&article=00025&type=abstract ]less than measurement error[/url] for 300 watts. Cadence is a more accurate measure.
Posted : 06/05/2015 11:04 pm
Quite an interesting article [url= http://www.cyclingweekly.co.uk/fitness/training/time-trial-performance-why-even-pacing-might-not-be-best-23148 ]here[/url] on time trial pacing. Can be quite fatiguing to try and ride rigidly to a rapidly fluctuating power value. Think for time trials you're better off mostly going by cadence and speed, keeping things smooth, and just having an eye on power for pacing. If you find yourself chasing power then you might be better off with 10 or 30 second averages.
Posted : 12/05/2015 9:16 am
[URL= http://i829.photobucket.com/albums/zz211/dansipods/93FA6D36-8DD2-4C4A-AF71-C9EA02721076_zpsb1op0um6.pn g" target="_blank">http://i829.photobucket.com/albums/zz211/dansipods/93FA6D36-8DD2-4C4A-AF71-C9EA02721076_zpsb1op0um6.pn g"/> [/IMG][/URL]
Posted : 13/05/2015 3:56 am
 DT78
Only 29km per hour must have been very very hilly.....
Posted : 13/05/2015 7:40 am
I just can't see how that's possible. He should really have a go at the hour record.
Posted : 13/05/2015 9:16 am
I'd be happy with that power over a 10 mile time trial, would get likely get you into the 20's. For a 3hr 20min effort that's mind boggling. Really is so many levels above your average club cyclist (like me!)
Kwiatkowski's world champs win is also worth a look ([url= http://home.trainingpeaks.com/blog/article/michal-kwiatkowski-s-world-champion-power-file-from-quarq ]here[/url]) if you like to try and comprehend that sort of thing.
Posted : 13/05/2015 9:32 am
Surely that's a 20 min average?!
Posted : 13/05/2015 10:00 am
That sounds about right, 4.8W/kg, you'll need more than that to be competitive on the road.
"De Kort’s 2015 Paris-Roubaix ride was equivalent to him riding at 321 watts (4.6 watts per kilo) for over six hours - an effort many amateurs would struggle to maintain for 20 minutes."
Posted : 13/05/2015 10:30 am
 DanW
100km and 2500m climbing on the course.
It would be interesting to know more about Kulhavy's power... 364W for 3 hours does seem a little high on first look although I guess you have to put that in to perspective with the road guys, for whom being 76kg is huge! 4.8w/kg then seems kinda do-able over 3 hours. Ramunas Navardauskas is a similar size to Kulhavy and had pics of ~330W for 5 hours during a stage race (forget which one!) and he is one of the stronger guys you'll see pull a peleton around. Kulhavy's pic could of course be normalized power rather than average power, or average power with the zeros excluded so there a lot of variables to understanding it.
On a related pro power theme, Lars Petter Nordhaug said on Eurosport his personal best 5 min power is just north of 500W and 435W for 10min.... at 63.5kg.
Posted : 13/05/2015 12:04 pm
Yes, one assumes there were quite a few zero values, the graph would be very interesting to see.
Meanwhile - [url= https://www.indiegogo.com/projects/limits-the-world-s-smartest-cycling-power-meter ]LIMITS[/url] isn't far off doubling its funding target.
Posted : 13/05/2015 12:15 pm
[Looks at my own, shakes head, continues with sausage and egg sandwich]
Posted : 13/05/2015 12:24 pm
 Jamz
Don't suppose anyone has any idea of whether Max2power might reduce their prices at some point over the summer (wishful thinking here!) according to DCRainmaker prices have been going down in the US recently for most power meters. I noticed if you buy a Max2power in the US it works out around 100 squids cheaper after converting to sterling.
Also, while you're on the subject of TTs - what sort of time do you think would be average for a 10 mile TT (about 350-400ft elevation gain) and what would be a respectable time? I thinking I might go try one and I'd like to have something to aim at. I know, I know, how long is a piece of string and all that, but Im just interested in a ballpark...
Posted : 13/05/2015 12:39 pm
I tend to go off lap avg for training or just messin', the 3 or 10s readings are a bit distracting. To beat my PB on a local 20min climb I know I need to average 360w, so I just hit LAP at the bottom and try to keep it somewhere around there.
Respectable time for a 10? Depends on so many things. If you're a pretty decent rider on a proper TT bike then under 25 mins should be doable and is usually a good first goal. Really you just need to do one to set a benchmark for yourself then go from there. If it's a proper TT course it should have a code associated with it (e.g H10/3) and you'll likely find a Strava segment for it.
Posted : 13/05/2015 1:01 pm
I gave up on the power plot and now just read off my 20, 5, 1 min and 5 sec power from my best efforts from Strava. Normally races. Sky won't be calling for their vets team any day soon 🙁
Anyway, this gets me across the line in the top third of E123 circuit races and 2/3 road races:
20 min 4.2 W/kg
5 min 4.6 W/kg
1 min 6 W/kg
5 sec 12 W/kg
To be a top performer, your power should DOUBLE from 20 to 1 min, and double again from 1 min to 5 sec. I'm not a sprinter and need another 4 W/kg. Another sandwich nurse!
Posted : 13/05/2015 1:55 pm
TiRed, that profile is almost exactly the same as mine. I am definitely no sprinter 🙁
Posted : 13/05/2015 3:09 pm
Welcome to Club Domestique 😉
My training is now almost exclusively STME - 20/40s and minute pyramids. I'm not expecting huge improvements, but am pleased to be in the mix at 47 and 68 kg.
Another sandwich nurse! And tramadol!
Picked the new Propel SL2 for added whiteness and lightness. Might go for left side vector now the pods are fixed.
Posted : 13/05/2015 4:41 pm
Thanks. I can't be bothered upping my top end, I'm consigned to testing.
Wasn't aware that the pods were broken. Mine have been fine! Improvements probably no bad thing though.
Posted : 13/05/2015 5:48 pm
The original pods have been cracking at an alarming rate when mounting (not in use), which has prompted a redesign and the option to “upgrade” for £60 a side. The new design doesn't use a washer, which I guess was the issue.
Any owners on here broken one? My clubmate has seen off several.
Posted : 13/05/2015 8:28 pm
I guess it's more of a potential issue if you swap them lots.
Posted : 13/05/2015 9:32 pm
i broke a Polar one during fitting when they first came out 😳
Posted : 13/05/2015 9:50 pm
Not at all! Consigned to not winning much, maybe, but Charlie never won a professional race in his career. I'm happy working for the team, after all, cycling is a team sport. Top third is my expectation, points are a bonus. Second Cat was a possible objective with a lot of Masters racing. I hope to be back by close of summer. And if the claim goes my way, I'll have a power meter on every bike 😉
500 Watts for five minutes is 8 watts per kg, which would be 6 watts/kg at 20 min (25% reduction to get FTP), then keep doubling FTP to get 24 watts/kg at 5 seconds. I need 16 watts/kg just to be competitive in the sprints. Impressive stuff.
But really, you don't need huge precision, just an appreciation of the power spectrum. And I work with numbers all day.
Posted : 13/05/2015 10:05 pm
 adsh
According to Stages and Training Peaks over the last 6 months I may be applying for a junior domestique place in your over 50s team:-
20mins 4.6 W/Kg
5mins 5.2 W/Kg
1min 6 W/Kg
5sec 10 W/Kg
Starting to want to verify my Stages - some big numbers on last nights commute. Sure I felt strong but 44W stronger after 4 months. Seems a bit of a stretch even if I was 2minutes 37seconds quicker over 8.9km
Posted : 14/05/2015 9:18 am
TiRed, sign me up! Only done one 34 crit so far but with our power profile I really don't see how I'd ever win a point! Maybe if it was cat 4 only and a smaller field (and not 150 riders with a load of experienced cat 3 guys) I'd have a chance, and maybe not crits either. Answer is probably race craft!
Posted : 14/05/2015 9:29 am
 beej
Interesting to see the power numbers.
Wattbike/Power2Max numbers, from Training Peaks
20mins 4.2 W/Kg
5mins 4.4 W/Kg
1min 6.8 W/Kg
5sec 14.2 W/Kg
Hey, maybe I should be a sprinter! But these are @66kg, so I've always considered myself a climber.
Posted : 14/05/2015 9:47 am
Well mine are quite flat..
20 min 4.6
5 min 5.0
1 min 6.8
5 sec 12.8
@72kg. Not raced much this year so hopefully should go up a bit over the next few months. I could probably do a bit better at 5, 1 and 30s but I've not done proper full gas efforts for those durations in ages. The 20 min was from a test in Feb so should be a bit higher now too. We all look much the same though, at least within the range of error for typical PMs.
We'd make a brilliant team of domestiques 🙂
Posted : 14/05/2015 10:03 am
Still no road racing around here so I've been concentrating on the MTB, shop I ride for is organising one race which will be the only road race in about a 150 mile area!! Went from long solid zone 2's into short efforts so I've not actually done an hour effort (let's be honest they're bloody awful anyway haha!!) longest ride this year has only been 3 hours!
@59kg (sometimes less 😯 ) so a good bit lighter than you guys, you'd all absolutely hammer me on the flat!!
https://www.flickr.com/photos/129593813@N03/17632308761/in/dateposted-public/
Really want a PM on the MTB, these are taken from the winter bike which is a heavy beast of a thing that sometimes leaves sprinting (and thus getting out and doing short hard efforts) a bit meh!
20 min - 4.76
5 min - 5.53
1 min - 8.77
5s - 16.23
3 podiums in (regional) sport so far this year, hope I can keep it up or better, improve. Fancy a National, top 10 would be amazing if I manage to get to one!!
Posted : 14/05/2015 10:33 am
At 72kg I'm beginning to feel like a bit of a fatty on this thread!
Posted : 14/05/2015 10:35 am
Haha, I'll trade you some weight! I know guys that can climb at the same speed as me most of the time but when it gets flat they ****ing kill me!!! Once the babies aren't babies you'll be killing it again mate!
FWIW losing 3-4kg this year seems to have cost me 200-250W from my 5 second power (not worked out 1 min but it's down), 20min and 1 hour (estimated) is about the same which doesn't bother me so much on the MTB but I'd really be wanting that back on the road!
Posted : 14/05/2015 10:40 am
Thanks for the trade offer monkeyfudger, though Mrs Blobby is already complaining I'm too skinny!
Interesting regarding the weight to power trade off. Assuming that overal it's been a positive results wise? The weight thing does put me off doing more xc racing though, getting back under 70 would be hard.
Posted : 14/05/2015 10:51 am
Difficult to say, I only done one XC race last year which was a 4th in Masters, flat course (Cathkin Braes) so no real way of comparing. I really didn't plan on being this light as I don't think it's that healthy...but I've been ill less, go figure!
I'll be putting a conscious effort in to gain weight over the winter this year, I'd like to hit 65kg as I believe I'll be road racing again (hopefully!), if I can hit the same W/Kg I reckon I can get some decent results.
I think it depends on how many hard efforts you can do, I'm not capable of hard effort after hard effort, I've really only got 2-3 in me so a big guy who can dig in again and again would beat me.
😀 you better keep the Mrs happy then!!
Posted : 14/05/2015 11:03 am
im 82kg fss 😆
5s - 12.76W/kg
1m - 6.74W/kg
5m - 4.38W/kg
20m - 3.83W/kg
Posted : 14/05/2015 5:34 pm
Posted : 18/05/2015 10:30 am
Link for the non facebookers (Flickr hates me/iPhone's now so I can't grab the IMG link)
https://www.flickr.com/photos/129593813@N03/17189839474/in/dateposted-public/
😛 at the first comment!
Posted : 18/05/2015 10:34 am
Wonder who's testing that?
Much market for a dual sided Stages? I'd guess it'd bump the price up beyond the likes of P2M or Quark, though it would be offset a bit by actually getting a full chainset and not just one arm! After everything I've read and heard about Stages I think my money would be going elsewhere.
Posted : 18/05/2015 10:41 am
I wonder if this is just the next step in their development, they've probably sold enough units to have clawed back their initial R&D investment by now and as we know the actual bits to make a PM are cheap, they could just release the new dual sided PM at the same price, smashing the price war down a notch again like they did at launch.
Massively jumping the gun here as its a proto but why bother using two batteries on a product that is effectively linked, you'll always need 2 batteries on pedals but this is missing a trick IMO. Stick a rechargeable battery in the axle and link the 2 pods. With one step you've removed the only complaint/problem people have with Stages and at the same time introduce a selling point.
And good luck changing that battery with the crank in place!
Posted : 18/05/2015 10:55 am
 DanW
SKY have used dual sided Stages pretty much from the outset of their sponsorship so this isn't too new. In their case there was a telling bright blue battery case on the DS crank arm.
If I were buying a PM today I'd still go for Stages and only Rotor InPower would make me think twice about this. The more expensive options wouldn't give me any advantages.
It is very interesting though, to see if true left/ right PM's can hit the market at a reasonable price point. I can't think off the top of my head but isn't a dual Vector setup the only "true" left/ right PM available at the moment? The spider based PM's measure right down + left up/ left down + right up to measure net work done on each side but don't completely isolate left/ right power as far as I am aware (???!)
Posted : 18/05/2015 11:28 am
Quite a few dual sided. Polar, Garmin and now PowerTap with pedals. Info Crank and Rotor with crank based. 4iiii and soon PowerBeat with crank based. I think Pioneer is crank based too.
Assuming MTB I think I'd actually go Quark if buying today. Seem a popular choice and don't hear much in the way of complaints.
Posted : 18/05/2015 11:37 am
 DanW
Sorry, I meant for MTB 😳 Pedal options aren't ideal for MTB, Info, Pioneer and Rotor don't do MTB versions of their dual sided.... are 4iiii making a solid product now after their problems? I realise MTB PM's are a niche market but I think a PM would have to be true dual sided to tempt my away from Stages or try the INpower.
There were a lot of issues with Quarq data going nuts then stopping transmitting completely, spikes in cold weather, power drift, water ingress and not being great at turning around warranty replacements quickly. Maybe this is fixed now and the XX1 unit is different to some of the road models but there was enough to make me think twice when buying (mainly the slow warranty work). That said, all PM's seem to have their issues from time to time
Posted : 18/05/2015 12:02 pm
4iiii are shipping LH pods, but they have to install them, $50 more than when they launched, which I think was always the plan. They're saying carbon cranks and RH pods will follow.
Shame they've had the problems they have, I still like the theory.
Posted : 18/05/2015 6:06 pm
4iii have my crank at the moment, but took so long in the first place that I bought a stages. Then I bought a kickr. So soon I'll have three power readings for comparison. The kickr and stages currently read within a few watts of each other. If the 4iii reports a higher value, then clearly the existing two are wrong 🙂
Posted : 18/05/2015 6:18 pm
Obviously you're kidding, but that is the trouble, you don't actually know! That in itself isn't an issue until you try and compare across systems, and do a session at 300 Kickr-watts, which is actually 350 Stages-watts!
Posted : 18/05/2015 6:27 pm
Page 12 / 30
