Just bought a new canyon spectral(go me) that comes with fox 34 forks and want to replace them with something a bit stiffer ie pikes. The forks are 150mm travel and boost but I can't with out which Pikes I need? Bonus point for finding a cheap source 🙂
150mm solo air RCT3 I'd guess. Don't know what offset the canyon comes with but you dont really have much choice when it comes to aftermarket as uncommon offsets are normally OEM. 46mm is normal for 27.5" fork I think.
FWIW I’ve 34s and pikes and can’t tell the difference between the 2, stiffness wise. I’d be looking at 36s/lyriks if I needed more.
I think you're daft for changing for stiffness reasons but Biketart are doing 2018 RCT3s (150mm) for £475 with the discount code
