Which mini pump/CO2...
[Closed] Which mini pump/CO2 to get a 29" 32c tire to 100 psi? :S
I got myself a pair of Roubaix Pro 32c and I love em, only thing is that they're a bit tight and need around 100 psi to seat properly on the rim which :S
Any mini pumps up to the task? Reckon it would need a hose and screw on attachment, then some insane number of pumps. Or just get CO2 and dump a 20g canister into it, hope it seats and then reduce the pressure down to its working 75 psi ish.
Posted : 24/11/2021 6:55 pm
Even the smallest Lezyne Pressure Drive gets to that pressure. Tiny, easy to carry and effective.
Posted : 24/11/2021 6:58 pm
Yeah seems like a good tradeoff between volume and reaching high pressure, the small one is 17 cm and weighs around 100g. Albeit I reckon it would take some 500 pumps to get a 32c tire to 100 psi with it.
Posted : 24/11/2021 7:07 pm
I use Blackburn airstick for mine.
Posted : 24/11/2021 7:08 pm
Frame pump? I've got a tiny little topeak mini pump thing for the road bike in summer as backup for CO2, but sod that on a cold wet commute.
I've got this one and can't fault it.
https://www.bikeradar.com/reviews/maintenance/pumps/frame-fit-pump/blackburn-frame-pump-review/
Posted : 24/11/2021 9:47 pm
For 100psi I'd skip the mini pump and go for a deeply unfashionable but very effective frame pump. I have the ever reliable Zefal HPX on my winter bike and can easily get to 100psi without wanting to kill myself.
It doesn't look great, but it's a winter bike. The thing looks like an audax bike anyway with mudguards and dynamo!
Posted : 25/11/2021 7:13 am
Why do you need a 32mm tyre to get to 100psi?
Run mine at 80psi @ 85kg
Posted : 25/11/2021 7:15 am
One CO2 cartridge won't get the tyre to 100psi IME, but why not try it at home -
I'm forecasting no more than 50psi, if that.
Posted : 25/11/2021 7:22 am
One CO2 cartridge won’t get the tyre to 100psi IME,
Normal co2 can is 12g. A 20g is nearly two cans.
But +1 for why 100psi. Weighing 200kg ?
Posted : 25/11/2021 7:34 am
All in the original post...
they’re a bit tight and need around 100 psi to seat properly on the rim
Posted : 25/11/2021 7:51 am
Sorry, didn't pick up all that blatantly obvious information. 🤦‍♂️
Posted : 25/11/2021 7:56 am
