Which cassette lock...
[Closed] Which cassette lock ring tool with Pro 2 Evo 12mm...
Evening,
Found that my 12mm thru adapter on my Pro 2 Evo hub fouls the cassette lock ring tool. Running a Sunrace 11T lockring. Is there a deeper lock ring tool to fit over the 12mm adapter and still engage with the lockring teeth?
Thanks
Posted : 20/10/2017 11:13 pm
You take the adapter off - do up the cassette and then put the adaptor on again.
Posted : 20/10/2017 11:37 pm
Thanks Ben. Problem is that the adapter doesn’t fit through the lockring so has to go on first. Funny design I think.
Posted : 20/10/2017 11:40 pm
Ahh. Do you have the 135 12mm adaptor by any chance? I know the 142 would fit (I've fitted a fair few!) but never a 135.
Posted : 20/10/2017 11:54 pm
Thanks Ben. I’m using the 142x12 for the Pro evo 2. It’s the black adapter with the silver ridged end.
Posted : 21/10/2017 12:01 am
Someone whos a bit more savvy than me can comment Im sure but... the 142 drive side adaptor for Pro 2 is silver with no ridges. Not seen one with ridges.
Posted : 21/10/2017 12:12 am
Thanks Ben. This is for the Pro 2 evo. The NDS adapter for me is silver no ridges...unless I’ve mixed them up?!
Posted : 21/10/2017 12:15 am
Drive side is silver, NDS is black. Also worth noting the 142*12 is called the X12 adaptor (there's also a '12mm adaptor'). I cant say I can remember whether theres a different pro2 vs evo version, but they were / are silver for the drive side on the Evo.
Posted : 21/10/2017 12:26 am
Bugger...I might have ballsed it up and using wrong adaoter! Anyone got a spare set of Pro 2 Evo X12 adapters?
Thanks Ben
Posted : 21/10/2017 12:28 am
