Which BB30 adaptors...
[Closed] Which BB30 adaptors for Shimano crankset?
Hi all, aplogies if this has been covered, couldnt seem to find anything in a search.
Looking for any recommendations for adaptors to run a Shimano M785 crankset (with Hollotech 2 BB) in a BB30 frame (stumpy fsr 29er carbon)?
Thanks
Posted : 30/10/2013 10:45 am
I've just fitted an FSA one for a customer. It's a press fit sleeve that's pushed in from one side and secured with Loctite. You WILL NOT fit it without a good headset press and nor will you ever remove it, but by flip is it a decent bit of kit. Totally recommended.
Posted : 30/10/2013 10:48 am
Many thanks for the info, Im definitely planning to get the LBS to fit it! Do the adaptors require any spacers at all? I'll be running 2x10?
Posted : 30/10/2013 10:52 am
This was on a Cannondale road bike. It fitted perfectly flush with the BB shell and to all intents and purposes made the frame into a perfectly normal English threaded BB. No spacers or any other faffing required.
Posted : 30/10/2013 10:55 am
Are there any brands you would recommend? As you can probably tell Im no mechanic, internet research seems to mostly come up with "Wheels manufacturing BB30 to shimano hollotech" adators for about £30?
Posted : 30/10/2013 11:05 am
Do they develop creaks like the other push fit efforts?
Posted : 30/10/2013 11:37 am
Praxis Works fitted to my Stumpy. Lovely and quiet.
Posted : 30/10/2013 12:23 pm
As I said above, FSA.
This one 🙂
http://www.chainreactioncycles.com/fsa-bb30-english-adaptor/rp-prod44067
Posted : 30/10/2013 8:15 pm
 cnud
I have one of those and it creaks. To be fair I didn't loctite it in which is possibly why, but if it isn't I'd be very peed off chiseling it out again. Gonna try a Praxxis Works before I start gluing.
Posted : 30/10/2013 9:11 pm
We tried a whole bunch of these adaptors and they were all shit, except the Parlee one which is what we fit to all bikes requiring this, its the only one that doesnt creak, and has descent longevity due to the enduro bearings and descent seals
Posted : 30/10/2013 9:17 pm
The adapters do come out. Took mine out as I wanted to fit campag press fit. Made a tool from a section of car exhaust, a bit of m12 stud, a big fat washer and a socket. Worked a treat and shaved half a pound off the bike.
Posted : 30/10/2013 9:27 pm
Which is bugger all to do with a simple adaptor sleeve - that's the bottom bracket!
Dunno where you get that from. The sleeve can't weigh more than 3oz!
So you didn't fit it correctly, then wonder why......? The one I fitted came with its own loctite in the packet.
Personally, I'd just leave the BB 30 in if I'm honest. Or not buy a bike with one in the first place. Which is exactly what I did. My Madone 2.3 has press fit and takes a Shimano crank. 🙂
Posted : 30/10/2013 9:42 pm
WIMW .. after the complete adapter/BB/chainset swap. Got rid of the more expensive FSA set up (after the cranks snapped) with cheaper and lighter (and hopefully more reliable) Campag Centaur.
Posted : 30/10/2013 9:56 pm
Peter P
the Parlee is a complete unit. hence it has a bbkt in it.
its the best unit there is on the market.IMO
Posted : 30/10/2013 10:08 pm
The praxix is good but for pf30 rather than bb30
Posted : 30/10/2013 10:42 pm
 LeeW
They fit both OB, you just have to take the sleeve off for BB30.
Posted : 30/10/2013 10:54 pm
Opps me bad , thanks that will teach me to pay more attention
I have been very impressed with the one I've fitted to my spearfish
Posted : 30/10/2013 11:18 pm
KCNC makes a beautiful adapter, similar to PRAXIS.
check out RWC website.. they have endura bearing options for that too...
http://www.enduroforkseals.com/
Posted : 31/10/2013 4:16 am
Yep. Watch out, BB30 & PF30 are not the same thing.
Posted : 31/10/2013 7:52 am
