Hello.
Looking for recomendations as to where to get a set of older forks seviced. Not retro ones by any means, I guess about 2012.
80mm SID RL 29" with a straight steerer and QR axle so an older model and I'm not sure of availablity of seals etc.
So, who would the masses recomend? Mojo/TF Tuned/Flotec/loads of others.
Plenty to choose from but no idea who's good and who's not. Looking for the 'best' rather than the cheapest, unless it's really silly money. Need them done by early July if that makes any difference.
Cheers,
Zyro/SRAM tech for anything rockshox
I've always used TFtuned. Great service and they should tell you if they can service the fork before hand if you just phoned them.
TF tuned have always had the consumables I need to service my forks/shock in stock, I'd use them if I was sending them off for a service.
Plush did a superb job on my old Fox 32s. About the same vintage as your SIDs and never serviced before. Came back like new. They had to obtain a no longer manufactured part for them too.
https://www.plushsuspensiontuning.co.uk/
Thanks Two out four for TF, I'll give them a call. Will give Plush a shout if they can't do it.
got a 2002 zocchi serviced at TFTuned last year!
