Where can I find hope XC bearings in Edinburgh? Do any of the bikeshops stock them? I'd prefer not to have to cycle out to the usual place in Newbridge to get them if possible. They're 6001. Also, do i need to replace the freehub ones at the same time (they feel fine) or can I just do the ones in the hub shell. Only ever replaced bearings in wheels without freehubs before hence the cluelessness.
Pretty sure we keep them in stock all the time.
Call tomorrow and i will check with James the mechanic what we have.
Failing that you can call Forth Engineering.
Mark
Any bearing supplier will stock them.
I only ever replace the bearings that need replacing, others can be left in until they start feeling rough, IMO
