I've bought a new rack and the bolts to tighten up bits are normal spanner head bolts. I can see this being a bit of a pain so i was thinking of getting some bolts that i can hand tighten (which will be tight enough) so a wing nut type head or plastic star or something but where from??
ta
I need one of these for my old car rack (don't currently use it, but it would be useful to have working again).
Anyone?
B&Q or Wickes
Sure they're 12mm?
The bolt diameter determines the size not the spanner needed [usually]
tried B&Q, Wickes, Screwfix and searched the net,
yep 12mm diameter (19mm head)
Stoner, thanks but i need a bolt not a nut
oops, sorry.
buy a cheap 19 spanner and tie it to the rack?
Try someone more specialist? - At work we use these chaps, who seem to be able to get hold of all sorts of weird and wonderful stuff...
http://www.butlerfasteners.co.uk/
try searching for M12 Thumbscrews
Go to your local ironmongers or nut and bolt/fixings supplier. If they dont have it, theyll point you the right way. Or even call in to a local engineering place and offer then a few quid. No doubt that that way, they'll just give you a few
ta Stoner, they'll do, good work!
