Where am I going wr...
[Closed] Where am I going wrong ?! Cable tension
Hi everyone, I have a problem that is most likely very silly indeed, so apologies in advance.
I recently had to service my One Up (V1) dropper post, so am now renewing the cable.
I have a problem where the tension on the dropper cable changes as i turn my stearing, the dropper works perfectly when there is a nice amount of tension but obviously doesnt work when the tension slackens.
This is probably a silly little thing that i am missing, please see me right
Posted : 16/06/2020 1:44 pm
Either your outer cable is not seated properly at the end, or its too short with not enough flex to cope with the steering movement....
Posted : 16/06/2020 1:47 pm
Either way, you shouldn't be putting tension on a cable by turning the bars. Install a longer outer and make sure there is no slack in the inner when you secure it.
Posted : 16/06/2020 2:29 pm
Remember that on the V1, it's the outer that activates the dropper. If the bend into the seat tube is too tight, or if there's a kink somewhere, it won't work properly. The cable just needs to be pulled through the lever until there's no slack.
Posted : 16/06/2020 3:32 pm
