When up from my for...
[Closed] When up from my forks came a-bubbling cruuuuuude
Oil that is, green gold, fox float tea. Letting a bit of air out my forks this morning and was greeted by a gush of foamy green oil. I can only presume that this is not good. Now they're well old and ****ed and there isn't a cat in hells chance I'm paying to get them looked at. So what's the diagnosis, theyre fox open bath (I think) float 120's (about 2006 off a stumpy fsr comp, but now on the dinglespeed monster tractor) any good servicing/fault finding tips?
Posted : 22/07/2014 12:19 pm
 gee
If you just pressed the valve you would expect a bit of oil to come out as there is 5cc of lube oil in the air chamber.
Do they still work?
GB
Posted : 22/07/2014 12:22 pm
Sort of, a bit firmer than they normally feel also abit of oil on the stanchions (which are worn so they do weep a bit anyway)
Posted : 22/07/2014 12:25 pm
Mine have done the same & its not all doom!
After a lot research (OK 30 seconds on google) it looks like oil from the lowers pushing past the air seal through a foam ring.
You can either do the repair yourself - essntially remove the internal foam ring (theres loads of tutorials if you google fox forks oil in air chamber)
Or remove all the oil and refil it - which will be my temporary fix as i'm off to the alps on Friday!
Posted : 22/07/2014 12:41 pm
