When does weight re...
[Closed] When does weight really matter?
[#9760110]
Coming from an XC background I've always read and been told lighter is better. Now I know it's not the case unless racing all the time.
So I did a bit of an experiment. My hard tail has DT Swiss M502 rims (30mm internal) on 350 hubs at 1905g and my full sus has Sram Roam 40's (21mm internal) but at 1608g. Last weekend i seapped the wheels over putting the lighter, narrower wheels on the hard tail for a muddy ride. They also had lighter tires so saved a good 500g in total. I didn't really notice the bike feeling lighter except for picking it up and on a few fast road sections. I've not yet ridden the full sus with the heavier wheelset but just wondering if it's really worth the weight penalty for a wider rim?
Posted : 09/01/2018 12:09 am
Hillclimbs
Posted : 09/01/2018 12:11 am
e bikes don't discriminate 😉
Posted : 09/01/2018 12:12 am
 ton
every man can lose a stone in bodyweight, for free.
Posted : 09/01/2018 12:14 am
Is your new hip ti or stainless tho Ton? should have gone for the TI option!
Posted : 09/01/2018 12:18 am
 ton
good old british stainless teej, or so i hope........ 😆
Posted : 09/01/2018 12:20 am
[quote=ton ]every man can lose a stone in bodyweight, for free.
which of my limbs do you advise me removing 😉
Posted : 09/01/2018 12:21 am
ton - Member
*targets 9st for 2017*
Posted : 09/01/2018 12:23 am
 ton
just cut your hair........hippy
Posted : 09/01/2018 12:25 am
Posted : 09/01/2018 12:27 am
Based on using single ply and dual ply tyres on the same bike, I find the extra half pound per wheel results In better momentum (helping the bike carry speed and roll over rough stuff) which for me outweighs the weight save. Surely if you’re climbing at a steady speed the rotating weight of the wheel doesn’t really matter. I can understand the slight reduction in acceleration and deceleration performance but the benefit of momentum must also play into it. It’s a balance.
Posted : 09/01/2018 12:30 am
@ton, i can try losing a stone, but are you sure 8st is a healthy option for a 5'9 guy?
Posted : 09/01/2018 12:31 am
Think ton's on about proper men 😉
Posted : 09/01/2018 12:36 am
 ton
i reckon it is about as healthy as 9 stone is. 😀
Posted : 09/01/2018 12:38 am
When it's the sum of parts. I can feel when I've lost or gained about 2kg of body weight.
So 1-2kg on a bike is significant on a climb.
People often say "it's only 300g difference". Do that across 6 components and you're nearly at 2kg.
Little weight differences add up, so if you want a light bike you need to look at every component.
Posted : 09/01/2018 7:49 am
Not sure how you have come to that conclusion. Lighter is better for me as I prefer riding light bikes. I don't race and my riding is solely for pleasure. Additional pleasure comes from riding a lighter bike.
It is that simple.
Posted : 09/01/2018 8:54 am
Where as I find additional pleasure in the additional comfort fat heavy tyres and wide wheels bring. I do ride rigid though
Posted : 09/01/2018 9:33 am
 JAG
Purely from a physics point of view then Mass affects acceleration.
Force = Mass x Acceleration
Less mass means less Force (energy or power) is required to accelerate at the same rate or that you can accelerate at a greater rate with the same Force (energy or power). So weight is ALWAYS involved.
On a bike it can be difficult to detect the change simply because there are so many other factors that obscure this effect.
As covered in some of the posts already.
Posted : 09/01/2018 9:37 am
@aazlad-bloke:
interesting point! Never thought this way around.
You say: on certain trails a "high momentum" wheel will be faster.
Might be.
@JAG-bloke:
This is correct.
But what aazlad-bloke says is also correct:
A "moving mass" has energy stored. Moving at the "same speed" the higher mass has more energy stored.
This - indeed - might help to
But also clear: aazlad-bloke has to put more energy into his bike.
If the trail is downhill: gravity helps.
Uphill: he needs to be stronger and always has to keep a "minimum speed" to gain from his "high momentum" wheels...
aazlad-bloke uses his wheels to store energy.
Mmhhh
Possible.
Might be the case for certain trail profiles and very strong bikers.
Posted : 09/01/2018 9:59 am
Soon after I bought my CX bike I changed the below:
Dropped 650g when changing the wheels
Dropped 300g when changing tyres too.
Dropped 300g by changing the cassette also.
= 1150g, 1.15kg weight saving.
The difference was night and day. Acceleration, running with it on my shoulder and overall agility of the bike was much improved.
I'm only 8.5stone and the bike weighs 8kg, so dropping 1.15kg was very noticeable.
Although, on the flat you might actually feel a benefit of heaver wheels as they roll for longer. Keep the momentum better. But give negative results on the hills or sprint accelerations.
Bike weight advantages are so subjective. 10 different riders will have 10 different views. Mathematically it must make a difference but the benefit of the difference has different affects on riders views.
A guy who is a lean racing whippet might have the fitness to not care about saving 500g.
Another guy with the same fitness level might not want anything to hamper his progress, so 500g is critical to him.
Another guy might be 19stone, so 500g may not make any noticeable difference to overall.
Another guy does not have the extortionate amount of pennies required to go hunting grams, so ignores weight figures.
Another guy just wants strength and dependability so does not give a sh1t about weight.
Build the bike that feels better for you.
You have to experiment yourself and decide yourself, on your own circumstances and what you are looking for from your steed or riding experience..
Posted : 09/01/2018 10:24 am
That would put me down at around 7 1/2!
Posted : 09/01/2018 10:26 am
 Bez
And you’d still have a stone to lose then, of course 🙂
Posted : 09/01/2018 10:30 am
Interesting stuff! I thought my DT wheels were heavy but after looking around they're lighter and wider than Hope tech enduro wheels.
After riding with 30mm rims with 2.3 tires (Maxxis DHF and Aggressor) there is a noticeable drop in grip when going back to 21mm rims with 2.25 Hans Dampf and NN which felt great until riding my other wheels/tires. Im only 60kg so never had a problem with burping tires or wheels braking.
2 things im tempted to try:
Wider tire on my narrower wheels keeping the weight down but might have an odd shape.
Lighter tires on wider rims. My current Maxxis tires arnt exactly light.
Posted : 09/01/2018 10:47 am
Medlow says it all really.
For me its
It is that simple.
Posted : 09/01/2018 10:52 am
Until you start hitting the point where the light weight parts aren't up to the job or perform worse...
It's never black and white, shades of [s]grey [/s]brown all over and endless compromises and balancing acts.
Posted : 09/01/2018 11:39 am
It's never black and white, shades of grey brown all over and endless compromises and balancing acts. [/quote}
I ride very simple bikes of very easy terrain and it is very black and white for me. I don't find myself making compromises let alone endless compromises and balancing acts.
Posted : 09/01/2018 12:48 pm
I've had some pretty light bikes in the past and enjoyed riding them at the time. The most enjoyable-to-ride bikes I've had were my last Orange Five which was built with 160mm forks and massive tyres which you could steam roller through stuff on and my current Alpine 160.
My riding is now solely for pleasure, given up on racing but for me, angles, tyres, the right amount of suspension and a dropper post = more enjoyment than something light. Of course I could chuck a load of money at making my Alpine lighter but I love riding it so I'll chuck the money towards Greggs and beer.
Posted : 09/01/2018 12:54 pm
kerley - Member
It is that simple.
I agree with this
the two are not mutually exclusive Tyres don't need to be heavy to be fat do they - My bike has relatively wide tyres but still weighs comfortably under 25 lbs which for me is the benchmark of a light bike
Posted : 09/01/2018 1:06 pm
You do make compromises and you are already balancing your needs, even if you don't realise it. You've found the optimum tool for your use case, but you could still go lighter again, I very much doubt you're at the limit of lightness.
The point is, as you have already acknowledged, your current riding is served adequately by your current equipment, and if your riding is consistent then your needs don't vary much.
If on the other hand your riding is extremely varied you have to make more compromises (or keep changing bikes mid ride!). One of your requirements is the feeling of a light bike, as it's important to you, it's also important to me, but not at the expense of other performance metrics.
If you moved or your riding changed you might have to compromise, either by changing your kit, or if the feel of your bike is more important to you, then by riding differently.
ie: I could use lighter wheels or tyres, but I'd end up walking home more often, so I compromise. Just because you've already reached your compromise doesn't mean you haven't made them, or balanced your needs already.
Weight may be important, for some it might be the most important factor, for others it might be further down the list, doesn't make either of those people right or wrong, it just means they have different requirements.
Posted : 09/01/2018 1:16 pm
I cant help but want another pair of wheels now. Just cant find any that tick the boxes:
27.5
15x100 and 12x142
26-30mm internal width
1.7kg or less
XD freehub
I'm only 60kg so don't need to be super strong.
Posted : 09/01/2018 7:45 pm
Maybe try these ??
https://www.bikeradar.com/road/news/article/dynamic-wheel-weighting-51327/
Posted : 09/01/2018 8:44 pm
If your'e really that worried about weight, have a crap, shave & a haircut before you go out on the bike.
Posted : 09/01/2018 8:50 pm
27.5
15x100 and 12x142
1.7kg or less
XD freehub
Hope pro 4 on WTB KOM i29 light spokes...
Posted : 09/01/2018 8:53 pm
Kryt's will know.
Posted : 09/01/2018 8:58 pm
I really don't. All that stops my bike being lighter is the fact I don't want to spend vast amounts of money on it (I do light on a small budget). I suppose that is a compromise but not the sort you are referring to.
Posted : 10/01/2018 9:23 am
 keir
I tend to operate on the basis that if everything else is equal, lighter is better, but having had some weight weenie times, and broken parts to show for it, weight is no longer a primary selection factor for me.
i now tend to go for the lightest parts that are reasonably priced and up to the task. a lot of the time i don't even look at the weights except on "big" stuff like frames, forks, wheels etc.
Strong. Light. Cheap. Choose two - as valid today as it's ever been
Posted : 10/01/2018 9:33 am
Definitely lighter bikes win out on climbing, but I also think a heavier bike does help on the descents. Bike tends to hold its line better with reduced tendency to ping off stuff.
So maybe the answer is to ride a lightweight bike to the top of the hill and then fill a frame bag full with rocks for the decent.
That would have the additional effect of gradually reducing the height of my local hills and in the very long term eventually remove the problem altogether.
Posted : 10/01/2018 12:11 pm
Excellent. This works. 😈
Funny:
Carbon sleds with Pinion gearbox.
These bikes are still 2 kg heavier than comparable plastic bikes.
The manufacturer of the Pinion sleds claim that this isn't a problem so...
Question then: are these bikes fun?
Do they win races?
Maybe above questions might help to answer this question?
Posted : 10/01/2018 12:23 pm
Does it matter according to what criteria?
Will it make you faster uphill? A bit.
Will it feel nicer to ride? Probably.
Will it fill the void? No.
I had an XC race bike which was 21.5lbs, with 1250g 26" wheels. That accelerated incredibly quickly, and by heck it was noticeable.
Posted : 10/01/2018 12:35 pm
I'll have to do a few experiments with my wheel and tire combos.
Just don't know if I'll really notice the benefits of going from a 21mm rim to 30mm on 2.25 and 2.3 tires. FYI most my riding is local woods, XC, and the odd trail center. FYI my wider wheels are nearly 250 grams heavier at 1908 grams.
Posted : 10/01/2018 10:09 pm
IME this depends a lot on what you ride, how you ride it and who with. Light bikes obviously feel faster to accelerate and take less effort to move around or climb hills with but there can be compromises in stiffness and sure-footedness. The lightest bikes I’ve owned were quick for XC thrashing but were not the most fun on technical terrain. Trails and the prevailing riding style have evolved in my local patch in recent years and that has been mirrored by less focus on bike weight and more on gnarrability.
Posted : 11/01/2018 10:13 am
All to do with where the weight is on the bike. Low down in the middle like the pinion has less effect than at the rear hub (Rohloff) or having heavy wheels etc.
Posted : 11/01/2018 10:41 am
@Stevet1
Good point. Rohloff maybe not the best pick for mountainbikes...?
Pinion: yes. Maybe even more fun / better ride due to VERY low weight rear wheel? Overall bike weight high so....?
Neat, new design:
https://www.deviatecycles.com/
"The Guide"
Can't find the total bike weight.
But possible that this bike will win races - athough it might be not the lowest weight Enduro bike?
But fantastic suspension...?
Posted : 11/01/2018 11:32 am
As a compromise has anyone put a wider rim on the front with a narrower rim on the back? Or upgraded to i wider rim just on the front to improve grip?
At the moment my OCD says don't do it.
Posted : 12/01/2018 12:57 pm
Easton Heists will pretty much tick all your boxes, 50g heavier at 1750g for 27mm internal but do everything else.
And cotic did a report on widths a while back, they said iirc 40f 35r was optimal so yes, a difference front to back.
Posted : 12/01/2018 1:49 pm
