wheels - ok or upgr...
[Closed] wheels - ok or upgrade?
[#3686315]
notubes ZTR rims on XT hubs: light and strong, or not a great wheelset? Using Maxxis tyres (Advantage). Wheels seem ok to me but if my memory serves not as light as on the the test Pivot Mach 5.7 I looked over, and wonder if they are worthy of considering for an upgrade?
Silly question - everything can be upgraded 🙂 - rephrase: are they a decent wheelset, or not?
Posted : 16/02/2012 11:04 pm
Which ZTR rims? All Stans rims have a pretty good weight/strength combination, they're probably fine. What bike are they on?
Posted : 16/02/2012 11:08 pm
ZTR Arch. On Ibis Mojo.
Posted : 16/02/2012 11:11 pm
I'd never though of xt hubs as being light.
Posted : 16/02/2012 11:14 pm
Decent for sure IMO, there will be better things to spend money on.
Posted : 16/02/2012 11:15 pm
Really need to know which ZTR rim in all honesty as there's quite a range now. XT hubs are solid working hubs but aren't the lightest out there. Are you running tubeless at all? A while ago my mate and I both had Yeti 575's and with basically the same build except for the wheels, I ran Goldtec's on Stans 355's and he ran Hopes on 717's and the weight difference between the 2 bikes was quite a lot. He did a lot of head scratching hehe
Posted : 16/02/2012 11:20 pm
XT hubs aren't all that light but not all that heavy (the rear hub weighs about the same as a Pro 2 with steel hub, if you want a direct comparison). 6-bolt ones tend to be heavier than centrelocks.
But nowt wrong with that wheelset.
Posted : 16/02/2012 11:34 pm
thanks all - when I have spare money, I'll not spend it on wheels unless they are square by then.....
Posted : 17/02/2012 7:52 pm
