Wheelbuilding Quest...
[Closed] Wheelbuilding Question
I've madly decided to build a new rear wheel (my first) for my fatty and have ordered a Mulefut 80 rim.
Can someone with more experience guide me towards what nipple length I should be using and whether I need to use nipple washers or not (I assume yes or no to washers will affect required nipple length)?
Posted : 07/02/2017 8:41 am
Go and spend £9 on Roger Musson's brilliant pdf book. It has answers to all the questions.
http://www.wheelpro.co.uk/
Happy fettling!
Posted : 07/02/2017 9:33 am
Does Roger cover that rim?
Your question sounds very specific to the rim. 12mm nipples are usually fine but if there's a deeper well to the nipple shoulder then longer may be needed.
Washers only needed on light rims IME.
Posted : 07/02/2017 9:40 am
@cynic-al
Yes I am being a bit specific. The rim is flat bed so I was just going to buy 12mm nipples. Then I saw a few posts on mtbr about cracking around spoke holes in fat bike rims and the suggestion that washers should be used to spread load.
Just looking for a bit of guidance as to whether washers are actually necessary and if sh whether to go for 14mm nipples instead.
Posted : 07/02/2017 10:24 am
Edit, ignore.
Posted : 07/02/2017 10:31 am
Spoke washers can help on non-eyeletted single-wall rims like many fatbike rims - it helps spread the load better. I used some Sapim concave washers and nipples on a recent carbon fatbike wheel build. 12mm nipples will be fine - longer ones only really needed with deep-section rims.
Posted : 07/02/2017 11:05 am
@dovebiker
You're a star, thanks very much.
Posted : 07/02/2017 11:24 am
Yes, if you are concerned, just use washers, they will help
Posted : 07/02/2017 11:26 am
Thanks for the replies everyone, much appreciated.
Posted : 07/02/2017 12:15 pm
 JoeG
I have a set of fatbike wheels on Mulefut 80s. They were built up by the LBS wheel builder, no nipple washers, not had a problem. I would recommend brass nipples as they are less likely to seize at the nipple hole in the aluminum rim.
Posted : 07/02/2017 5:58 pm
 JoeG
double post
Posted : 07/02/2017 5:59 pm
Getting brass nipples. Heard too many stories of alloy nipples breaking.
Posted : 07/02/2017 6:01 pm
