whats the current o...
whats the current opinion on stem lengths?
A few years back, everyone banged on about shorter being better. Every bike review suggested swapping to a 35mm stem immediately as product managers couldnt keep up with fashion.
Then anything with 120mm travel and up started coming with a 35mm.
Then seat angles got steeper. Obviously any mtb needs to be sized by standing position (so reach, or reach+stem, or maybe including stack height....) but there is a physical limit where you do have to do seated pedalling without overstretching your back too.
That seems to have cooled off now, and bikes that would have come with a 35 now come with a 45-55mm as standard.
The new scalpel (which is now a 120 travel, 66.5 HA bike) comes with a 70mm stem. Go back 6 or 7 years, my Bird Aeris 120 had similar stats but with a 35mm stem. Other figues were obviously different to make it fit a static rider, but in terms of steering feel, which is correct, or can both be?
A coaching session in the autumn revealed that I have my weight too far back, and while obviously I can and am trying to adjust my physical position on the current bike, a slight forward weight shift and slower steering would, I think, help me weight the front whilst also keeping confidence that the steering is still going to work.
But I dont want to take it too far and end up with the handling of a 10 year old steep bike where the front tucks under. I had that on a mk1 solaris, still got the scar.
Anyway, I'm sure I'll get 15 conflicting opinions and I''m not even sure exactly what I'm asking for.... but any ideas or experiences?
Posted : 23/01/2025 2:24 pm
mboy and mboy reacted
How best would you describe your frame 'size'; too small, too big or about right?
And (siting down-wise) do you use a straight seat post or layback, and where is your saddle positioned; centre, forward or rearward?
Posted : 23/01/2025 2:29 pm
Royston and Royston reacted
Just do whatever works for the riding you do. Think about two riders with the same leg and torso sizes, but different length arms. If they rode the same sized frame on the same trails, the one with longer arms would need a longer stem to fit on the bike the same. Just experiment and find what suits you.
Posted : 23/01/2025 2:32 pm
b33k34, submarined, J-R and 7 people reacted
I went through exactly this myself, shorter and shorter over the course of about 4 or 5 bikes, right down to 35mm, and then I've gradually gone back to around 45/50mm for most mountain bikes.
Posted : 23/01/2025 3:02 pm
On my current LLS bikes with 500mm reach, 35mm stems on both. When I was forced back onto a bike that was a bit smaller I went back to a 50mm stem and really didn't like it. Even the smaller bike handled better with the 35 for my tastes. (disclaimer: I'm not much of a 'cyclist' I just pedal around looking for jumps and steep stuff)
I don't buy into all this stuff. Look at the arguments we've had on here about high rise bars! Adding or removing a few millimetres of stem, headset spacers or handlebar doesn't just tip your entirely rigid body into the wrong position and ruin your handling. Not if you have flexible elbows and wrists and hips. Especially when you're standing up in attack mode, your bodyweight is wherever you place it.
The length of a stem has a real effect on steering feel so adjust this to suit. Everything else is just getting your hands into a comfortable place and learning to ride the bike.
Posted : 23/01/2025 3:12 pm
LAT and LAT reacted
How best would you describe your frame ‘size’; too small, too big or about right?
6ft and a bit, 2021 Santa Cruz large. 6'1 is SC's changeover between L and XL. I think I'm slightly longer in the leg and shorter in the torso than "average" for my height.
Straight seat post, saddle forwards. With my long legs and SC's slack actual seat tube mean I think I'm just returning to "neutral". Nose of saddle is still behind the BB.
I never felt cramped - but until this coaching where I saw a video of myself, I didnt realise how much I pushed myself rearwards. I know that on its own, the extra inch of top tube on an XL or a longer stem wont be able to correct this.
Posted : 23/01/2025 3:17 pm
What does your arm position look like?
If you're too far back and your arms are bent and elbows are out then a longer stem may help.
However if you're too far back with straightish arms, all a longer stem is going to do is move your crap body position slightly forward and make you slightly more likely to go OTB.
Posted : 23/01/2025 3:23 pm
Look at the arguments we’ve had on here about high rise bars! Adding or removing a few millimetres of stem, headset spacers or handlebar doesn’t just tip your entirely rigid body into the wrong position and ruin your handling. Not if you have flexible elbows and wrists and hips. Especially when you’re standing up in attack mode, your bodyweight is wherever you place it.
I discussed this on here a while (5 years or so) back and was told I was wrong, but maybe fashion is catching up with me!
I swapped to a 70mm Stem on my Scandal because (especially when clipped in) there wasn't enough weight over the front.  The Scandal has similar geometry to the Scalpel.
Yes you can solve that by adopting an even more aggressive riding position, but you still need to be comfortable on the rest of the trail that isn't ridden in full attack mode.  What works on a DH bike might be a massive compromise on a flat corner.
MTB'ers and the obsession with 35mm stems + 800mm wide flat bars is the new Roadies with slammed stems from circa ~2010, or Much Better (with) Raisers Magazine from the 2000's.
I've got a fairly stubby stem on my other bike, but:
a) it only has flat pedals which I'm convinced makes a difference
b) it works, and that's the key thing. If it makes you faster, safer, more confident then it's a good thing regardless of what someone on the internet thinks.
Posted : 23/01/2025 3:52 pm
I’ve settled on 50mm stems. But once stems are this short then the actual bar sweep (not the angle but the set back of your hands vs the steering axis due to both sweep and any effects of bar rise) matter a lot.
So on my two bikes I’m running the same bars and stem but one has the bars rolled back more than the other so there’s about 5-10mm difference in how far forward my hands are (they’re both 40mm rise so the roll makes more of a difference).
Posted : 23/01/2025 4:11 pm
a) it only has flat pedals which I’m convinced makes a difference
I'm pretty much exclusively flats off road, what is the difference it makes?
I found an old PB article where this was measured. Straight line through the middle of the grips, vs centre of steerer. Interesting in that (for example) a 35mm stem might get your hands 5mm off the steering axis. Swapping to 50mm (and bars remaining the same) would chnage this to 20mm off the steering axis which proportionally is a big difference - its four times bigger.
However going from a 50 to 70mm stem in the same scenario might change the key dimension from 20mm to 40mm, only twice as long.
You can see how on road bikes, with stem plus the offset to the hoods being in the 150-200mm range, stem length changes make minimal difference to handling and could be considered a purely static fit adjustment.
Posted : 23/01/2025 4:27 pm
I’m pretty much exclusively flats off road, what is the difference it makes?
Unless you have some special SPD shoes with mid-position cleats you'll generally be slightly further forward on flats. So in terms of weight distribution the flat pedals do the same thing as lengthening the stem.
Posted : 23/01/2025 4:48 pm
My opinion is that stem length is a tool to adjust steering characteristics, not for bike sizing or weight distribution, thats a hangover ftom road bikes.
Side note, if you were to design a road bike from scratch, would the right solution be to run a 100mm stem?
Posted : 23/01/2025 4:57 pm
silvine, convert, silvine and 1 people reacted
40-50mm is my preferred range on modern geometry bikes.
Currently have a 40mm with 800mm bars on my Moxie hardtail and 42.5mm with 780mm bars on my Aether 9c short travel bike. Both with 42mm offset forks FWIW. I just like the way my bikes steer with this length and then to some degree tune my weight balance on the bike via bar height/stem spacers.
Posted : 23/01/2025 5:10 pm
TBH I think it's pretty complicated purely because there's a human involved and we're highly adaptive and just tend to get used to whatever we already have, so even things that on paper are 100% improvement can feel weird and wrong.
I've ended up with 32mm on both my main bikes, but they're quite modern and reachy. My one shorter bike still has a 50mm on it and I don't like it with anything shorter, and likewise my last bike just didn't really work well with shorter than 50mm, it got waggy. TBH stems are cheap enough to fanny about with, especially since they're a good used buy (as long as you don't fall for buying super expensive nonsense, basic stems are fine)
Posted : 23/01/2025 5:23 pm
ThePinkster, LAT, BadlyWiredDog and 3 people reacted
I went through exactly this myself, shorter and shorter over the course of about 4 or 5 bikes, right down to 35mm, and then I’ve gradually gone back to around 45/50mm for most mountain bikes.
This. I went down to 35mm but didn't like how the bike handled so have settled on 50mm as my sweet spot for general duties bikes.
Posted : 23/01/2025 6:45 pm
I don't disagree, but weight distribution is an important factor in how a bike handles. And that's impacted by the relative position of the bars to the front wheel.
Road bikes are a novelty in this regard as their design is basically dictated by the UCI.  If you wanted to build the fastest bike for a bike race it would probably look more like this:
Posted : 24/01/2025 8:31 am
deanfbm
I've often wondered this. Why not employ forward geometry and get rid of the floppy steering and toe overlap? I can't imagine there's any downsides?
Posted : 24/01/2025 8:57 am
peteza, ditch_jockey, peteza and 1 people reacted
For me, it depends on the bike and I think the sizing / my positioning. I have two very similar, modern enduro bikes with one big difference, one has a 20mm longer reach than the other. I tried stems on both bikes from 30mm to 55mm; five different sizes. I can definitely notice the immediacy of steering dropping to the 30mm. However…
30 mm stem on the longer bike feels spot on with no loss of front end grip.
45 mm is perfect for my shorter, most used bike, which doesn’t actually feel shorter, although clearly it’s negligible.
Both bikes have the same bars and roll and neither bike suffered notable grip issues from different lengths. The main differences for me were how centred I felt on the bike and how the bike felt in fast tight turns. 🙂
Posted : 24/01/2025 9:01 am
 mert
I’ve often wondered this. Why not employ forward geometry and get rid of the floppy steering and toe overlap? I can’t imagine there’s any downsides?
It pushes the front wheel out, makes drafting harder and TBH, road bikes *don't* have floppy steering when they are being used as designed. Toe overlap is massively overstated as an issue, i have it on all my bikes, even those with short cranks and haven't had a toe to tyre incident in 35 years. I've even gone to a semi midfoot position (cleats are now 20mm further back than was possible with the standard slots) and *still* haven't had an issue.
For touring/gravel/cx, forward geometry would probably work really well.
Posted : 24/01/2025 9:09 am
nickfrog, AD, AD and 1 people reacted
Never liked the really short stems with a 170/180mm travel fork, I just can't weight the front wheel properly, I can see the appeal with shorter travel steeper head angle bikes but for me it's 45 minimum, but typically 50mm.
Posted : 24/01/2025 10:09 am
Mostly yeah, but I'd say it's about 70/30.
If I'm on a bike with about 460mm reach then a 40mm stem works best.
Moving up to 470-480mm and I'm back on my trusty 35mm stems.
There's a bit of fine-tuning for weight distribution basically.
Posted : 24/01/2025 10:17 am
peteza and peteza reacted
That's generally how things have been evolving.  Road (racing) bike stems seem to actually be getting longer with Large bikes now often coming with 120mm stems.  Whereas non-race bikes 100mm stems and frankly obscenely tall headtubes has become normal (along with shorter and shorter reaches).  I've only got short legs so that's made finding a new 'audax' bike surprisingly difficult.
MTB'ers overthink road geometry and handling.  Road bikes handle just fine as they are.
And especially for riding in a bunch you really don't want "stability" or a longer wheelbase.  One of the accreditation drills at the velodrome is to ride round with approximately 1 1/2 bike length gaps on the pursuit line and on the whistle the last ridder has to sprint up through the line slaloming between each rider. You need the bike to change direction quickly, not set it up for a corner.
Toe overlap is a thing if you try and do a slow u-turn on a fixie.  JRA you simply never turn the bars far enough, and with a freehub it's a complete non-issue
Posted : 24/01/2025 11:45 am
LAT and LAT reacted
There really is - I had a couple of frames built like this and found some real negatives for a drop bar bike. Going for a moderate adjustment of reach and stem length is good, going too far just upsets the weight distribution of a good drop bar bike ime. Toe overlap can be sorted on most frames w/o going too far from the norms of road stem/front end geo layouts.
MTB cornering techniques are not the same road bikes, road bike tyres don't slide and the steering is initiated differently. Gravel bikes can be somewhere in between, but all in all imho if you have a light drop bar bike it needs to be a good road bike as much as an off-roader and I found having to compensate for MTB-style fwd geo when riding on the road got old very quickly. But since a skinny tyre drop bar bike will never be that great on more interesting off-road trails at speed, the fwd geo approach wasn't much of a gain there. (edit for clarity, when I say fwd geometry style I mean in the range where you're half way toward or closer to MTB reach and stem ratio and front-reac centre balance than trad road bike proportions)
Posted : 24/01/2025 12:42 pm
Currently happy with 50 for trail, 70 for more xc type stuff and 90 for gravel. Tall with long arms. Tried shorter for xc and trail but prefer those lengths. Haven't tried shorter on the gravel bike because 90 was as short as Redshift went at the time and it's likely I'd end up banging my knees on the bars.
There was a theory a couple of years ago from some pros that they didn't like a stem shorter than the fork offset. I can't quite remember what the logic behind that was?
Posted : 24/01/2025 1:02 pm
"There was a theory a couple of years ago from some pros that they didn’t like a stem shorter than the fork offset. I can’t quite remember what the logic behind that was?"
That was one of those theories which was 99% a load of coincidence. Stem length isn't really a thing in bicycle geometry - the two numbers that matter are forward offset of the grips vs the steering axis measured vs the steering axis and measured horizontally.
If handlebars were straight tube then the stem = fork offset idea could be a decent hypothesis but they're not even close to being straight!
Posted : 24/01/2025 1:53 pm
yoleus and yoleus reacted
This guy has his theories. Pretty sure I've never pushed a bike hard enough to experience it though.
Posted : 24/01/2025 1:59 pm
jamj1974 and jamj1974 reacted
IIRC, my '20 Voodoo Marasa came with a 50mm, which has always felt fine with a ~720mm bar.
IIRC, my '16 Voodoo Wazoo fatbike came with a 75mm, I swapped it to a 35mm when I fitted 747mm Knuckleball bars and it felt dangerously twitchy on tarmac sweeping descents... Swapped it out for a 110mm and it felt great.
Posted : 24/01/2025 2:54 pm
It's in the video above that @mattrockwell just posted. Something to do with understeer.
Posted : 24/01/2025 3:00 pm
 Gaah
Put simply alters the weighting of your front tyre. So stands to reason it'll be more noticeable when cornering.
Bar sweep and roll can of course also put your hands behind the front wheel axle.  But any downward forces from your hands still go through the stem/bar interface when loading the front tyre. Not the fresh air below your grips.
A stem shorter than your fork offset shouldn't be an absolute deal breaker though. it simply means you'll be required to compensate with body weight/position and the forces you put through the front of the bike. But we have to do that with ALL set-ups anyway.
It's all a compromise. Just don't compromise so much it's to your detriment.
Posted : 24/01/2025 11:38 pm
I just watched that video about stems and bars. So he starts off talking about the clear differences between the steering behaviour of 40, 45 and 50mm stems and relating it to his 44mm fork offset (to the point that he says he’s thinks a 44mm stem would be better).
He then talks about various bars which have 7, 8, 9 and 10 deg backsweep. Here he’s talking mostly about compliance and how the resulting grip angle affects your wrist comfort and arm position (7 most attacking but least comfortable and vice versa).
The thing is, unless I’ve forgotten how to do trigonometry, that 3 deg angle difference across ~350mm of bar width (centre to grip) is ~18mm difference in longitudinal position at the grips. Ok, maybe the bars don’t sweep consistently from centre to ends but even a third of that change is bigger than the 5mm change between 45 and 50mm stems.
I don’t disagree that this stuff matters a lot - I can feel really tiny differences, just a few mm and I’ll notice. But I think the stem matching fork offset theory is people using poor science to support a coincidence.
Posted : 25/01/2025 10:39 am
thols2, ayjaydoubleyou, jameso and 3 people reacted
An excellent phrase. It might turn out to be the most concise summary of everything that happens in 2025.
But back to the cycling context - I refer you to The L-Shaped Crank
Posted : 25/01/2025 11:26 am
That video .. clearly he can out-ride me but .. your weight distribution comes mainly from where your BB is relative to the axles. Front-rear centre balances. The majority of your weight goes through your feet. After that it's geometry eg HTA and how far behind the front axle the stem ends up. Changing your bar/stem spec will move you back and forth a bit but if you look at how your weight is split between f and r wheels on a bike when you're in a neutral position, and then move about, you see that the change in weight on the front wheel is small compared to the split the axles to BB dimensions create. Certainly 5-10mm on a stem makes little odds there.
You also don't want to be propping up too much of your weight with your arms, you want to stay fairly neutral so you can weight or unweight the f wheel as needed, that itself shows how little weight we 'push' the front wheel down with. Compare the pressure on your grips with the pressure on your pedals. There's times when you're compressing in a corner or trail compression but generally the BB are is compressing equally too so the split is similar.
The stem matching fork offset theory - if that's about stem length and the leverage on the streerer in a corner and under/oversteer, it has to take trail into account since trail is what produces the torque on the steerer tube, not offset. Offset is just something that influences trail. Short vs long offset feels different in some ways but relating it to stem length seems a bit like the whole KOPS thing, as CGG says, a coincidence. He's describing what he feels so that in itself won't be wrong but I think the theory of why it feels that way wouldn't line up the same on a different bike geometry eg a shorter ravel XC bike. 5-10mm of stem length won't be changing weight distribution much at all, just the steering feel or feedback.
Posted : 25/01/2025 1:34 pm
peteza, wheelsonfire1, nickingsley and 3 people reacted
 Gaah
In your haste to outscience and overthink one another it seems some of you may have inadvertently forgotten that the stem is acting as a lever. Irrespective of offset, trail or anything else.
Posted : 26/01/2025 12:58 pm
“ In your haste to outscience and overthink one another it seems some of you may have inadvertently forgotten that the stem is acting as a lever. Irrespective of offset, trail or anything else.”
The stem is one part of the stem+handlebar lever. If the total handlebar backsweep equals the stem length (easily done on a 35mm stem) then the stem has zero leverage.
Posted : 26/01/2025 1:23 pm
jameso and jameso reacted
 Gaah
your assumption is completely wrong
independent of bar sweep or hand position the stem still always acts as lever. in all directions
Posted : 26/01/2025 1:29 pm
This is one of the most interesting threads (for me) in a while and nobody has fallen out yet…. After a lot of measuring involving bits of string I fitted some lovely Shimano Pro, 800mm carbon bars that I won in the megasack with a stem much shorter than the 90mm fitted to my 2000 model Orange Gringo. My main objectives were reducing the leverage so I didn’t go, or feel like,  I was going over the bars and to keep my torso in the same position, i.e. not too much weight on my wrists. It worked and although the steering felt more twitchy than before (probably just easier and quicker) it achieved the objectives. The geometry talked about above is interesting and what I was trying to calculate with my bits of string! If anyone can post up some diagrams as an additional explanation I for one would be very grateful. My more modern fat bike has better geometry, 800mm Shimano Pro carbon bars and short stem and is lovely to ride too.
@jameso @chiefgrooveguru what else have you got to do on a damp Sunday??
Posted : 26/01/2025 1:48 pm
“your assumption is completely wrong
independent of bar sweep or hand position the stem still always acts as lever. in all directions”
I’m sorry but this is basic physics. I’m sorry you disagree but if you don’t understand then I can’t help.
@chiefgrooveguru what else have you got to do on a damp Sunday??”
I went MTBing before the storm arrived. I’m now making lunch for the family. I’m going bouldering later with my eldest. In between I’m trying to wallpaper the inside of an old radiogram which is a horrible job and I’d rather argue about geometry…
Posted : 26/01/2025 1:59 pm
I don’t want an argument, I’m just keen to learn. Admittedly at nearly 65 I might have known all this stuff at some point but have forgotten it all!!
Posted : 26/01/2025 2:16 pm
 Gaah
Educate me.
For simplicity. Say you were to fit a zero degree 100mm stem and a set of flat curved bars with the exact amount of sweep to place your hands directly inline with the steerer.
Pushing on the grips straight downwards in line with the steerer tube. where will that downward force act?
A. Downwards with a twisting moment where the bars are held in the stem clamp causing the stem to act as a lever .
or
B. directly and only straight down through the centre of the steerer not causing any leverage on the stem at all?
Thank you in advance for taking time away from your busy schedule to help me.
Posted : 26/01/2025 2:28 pm
Exactly. The leverage comes from the position of the hands (which exert the force) in relation to the steerer. If the hands are in line with the steerer, there is no leverage. Wide bars with a lot of sweep will reduce the leverage that a longer stem creates.
Posted : 26/01/2025 2:30 pm
“ I don’t want an argument”
Are you sure, I can do 5 minutes or the full half hour! ?
Bicycle steering and handling is super complicated and no-one really understands what’s going on. But you can break it down into digestible bits - and when discussing stem length the correct discussion is about effective stem length, not actual stem length.
Some old threads on this:
https://www.singletrackworld.com/forum/topic/shorter-stem-advantages-disadvantages
https://www.singletrackworld.com/forum/topic/stem-how-short-is-too-short
https://www.singletrackworld.com/forum/topic/to-all-who-have-never-tried-a-35mm-stem
thols2, chakaping, chakaping and 1 people reacted
@Gaah can we have a discussion on here without sarcasm? I for one find it interesting and rudeness will not help participation from others!
Posted : 26/01/2025 2:33 pm
Posted : 26/01/2025 2:41 pm
@thols2 Thanks, I enjoyed that!
Posted : 26/01/2025 2:47 pm
 Gaah
@Wheelsonfire
I wasn't being sarcastic at all. I genuinely want the guy to educate me.
I'm not looking for any kind of argument either. It's simply an interesting subject.
@Thols2
"If the hands are in line with the steerer, there is no leverage."
with bars with excessive sweep when loaded downwards with enough force you will literally be able to see the leverage in the form of flex. same with excessively long stems.
@Chiefgrooveguru
"Bicycle steering and handling is super complicated " You're certainly not wrong there. There is indeed a lot going on. But I wouldn't go so far as to say "no-one really understands what’s going on".
Relating the physics to real life (ie. actually riding the bicycle) is where it gets more difficult and somewhat subjective to understand exactly what is going on and why.
Ps. did you miss my previous question or was I simply so polite you also mistook it for sarcasm?
Posted : 26/01/2025 2:57 pm
I’m cutting bits of wallpaper to the nearest mm but will reply when there’s a window of opportunity!
Posted : 26/01/2025 3:15 pm
To the OP, if your bike has ‘modern’ MTB geometry (steepish seat angle, longish reach etc) and is the right size for you, then it’s likely you only need to nuance your bike fit and bike handling characteristics within the 35-50mm stem range.
What works for you is likely to be influenced by a combo of factors such as head angle, stack height, fork travel, handlebar length and handlebar backsweep. But I doubt there would be ‘wrong’ stem length for you, and I agree with your observation that bike manufacturers have decided to split the difference by shipping 42/45mm stems.
On my trail bike (Starling Murmur) I’ve tried 35, 40 and 50mm stems as I have all three in the shed. I’ve settled on 40mm as a happy middle ground - there were no odd steering characteristics and my shoulders /arms were nicely relaxed on longer rides in the saddle. I’ve coupled this 40mm stems with a SQLab 12 degree backsweep bar at 780mm, and this backsweep has had a much bigger effect on steering and comfort than stem length did.
Finally, I’d be careful not to use a longer stem to fix the feedback you’ve had about keeping your weight back….I’m not a longer stem is needed to bring your weight forward. Perhaps a higher rise bar would, in the first instance, help with downhill confidence and weight distribution. This is only a suggestion, as I don't know your set up of course. Good luck!
Posted : 26/01/2025 5:02 pm
merk and merk reacted
 Gaah
 Gaah
@chiefgrooveguru
Posted : 28/01/2025 1:42 pm
Isn't it? -
Moment about steerer = Hand Force X Hand Distance from steerer (stem length and bar sweep doesn't matter)
But if hands are forward or behind steering axis, your hands move in a variable arc relative to steerer, so there becomes a translational or x/y force component (stem length and bar sweep matters).
But yeah, matching stem length to offset is nonsense. As someone pointed, offset doesn't matter, its trail and wheel flop with reference to hand placement versus steerer that matters.
Posted : 28/01/2025 2:14 pm
 Gaah
the forces weighting the front wheel are far greater than those turning the bars /wheel
Posted : 28/01/2025 2:22 pm
Weight on the front wheel too as a factor disregarded in the stem length versus offset nonsense.
In other news, I think all parties are partly correct, hands relative to steerer is part of the puzzle, as is bar sweep and stem length (whether hands are in line with the steerer).
Some more hands relative steerer stuff, if the stem is really long, so big hand to steerer offset, you're not really turning the bars as in pushing/pulling directly back with your hands in a "y direction", you're also pushing/pulling to the side in the "x direction", I think that's a good way to picture it.
Posted : 28/01/2025 2:40 pm
Some more hands relative steerer stuff, if the stem is really long, so big hand to steerer offset, you’re not really turning the bars as in pushing/pulling directly back with your hands in a “y direction”, you’re also pushing/pulling to the side in the “x direction”, I think that’s a good way to picture it.
Pretty much how road bikes work.
The hoods / drops are ~200mm forward and ~200mm sideways from the steerer.
Roadie steering tip that I only learnt the other day, when coming up the inside line in a chaingang and need to look behind to see if you've got clearance to pull out to the right, drop your left elbow, you can then look behind  / right as long as you want without inadvertently following where you're looking!
Posted : 28/01/2025 3:08 pm
 Gaah
Road bikes give a pretty easy to understand example of @chiefgrooveguru's (correct) assumption that hand position alters weight placement and the forces going through the steering axis. But that doesn't mean stem length used to get that position has no affect on where and how those forces are applied or the leverage they'll produce.
Hand/grip position relative to steerer axis. Is a product of stem length and angle and bar length, shape, roll and grip position. But two identical hand positions achieved by different stem lengths and correspondingly different shape bars won't transfer forces in exactly the same way.
Posted : 28/01/2025 5:17 pm
But two identical hand positions achieved by different stem lengths and correspondingly different shape bars won’t transfer forces in exactly the same way.
They will transfer the forces to the steerer exactly the same. The only thing that matters as far as the force on the steerer is concerned is the position of your hands relative to the steerer. There might be more or less flex with some bar and stem combinations but that's not what determines the force acting on the steerer.
Posted : 29/01/2025 12:43 am
b33k34, jameso, leffeboy and 3 people reacted
 Gaah
Oh I agree that turning forces perpendicular to the steerer would be transferred more or less the same. What I'm disagreeing with is that all the forces loading the stem in other directions would also be transferred exactly the same.
Posted : 29/01/2025 1:15 am
What I’m disagreeing with is that all the forces loading the stem in other directions would also be transferred exactly the same.
If your hands are in the same position relative to the steerer, the forces on the steer will be the same. The path they take to get there is irrelevant, the only thing that matters as far as the steerer is concerned is where your hands are. Sure, if you had a two foot long stem and bars with crazy sweep, the stem and bars would be loaded differently than a short stem and straight bars, so they would flex like mad, but the forces at the steerer would be exactly the same under a static load. It's the same as those silly Z shaped cranks, all they do is weigh more and flex more, they make no difference to the forces acting on the BB axle. (If you put shock loadings through the system, the flex in the bars and stem will soften the shock loading at the stem, but that's not what we are talking about here.)
Posted : 29/01/2025 3:42 am
 Gaah
I still disagree. The forces exerted through steering and weighting a bike are far from static and you simply saying that the forces will be the same isn't exactly a convincing me to think any differently.
those cranks have no relevance to what we're discussing here.
Posted : 29/01/2025 4:54 am
I still disagree.
chiefgrooveguru knows what he's talking about. I understand the intuitive appeal that different bars and stem should make a difference, but it doesn't. Intuition is not a good guide on this one.
Posted : 29/01/2025 5:56 am
I guess the best way I can explain this is:
1. imagine the grips are on the end of a massive chunk of aluminium billet, that is glued or welded to the steerer tube. Those grips are in the same place vs the steerer tube as with your favourite bar and stem combo (for me that’s 50mm zero rise stem and 760mm 40mm rise Renthal bars).
2. Then machine away the rest of the billet so it looks like your fav bar stem combo.
3. Get another billet and machine away a total different shape, just leave enough material there for it to be stiff enough.
4. Do the same again but go wild - make some silly shapes in between steerer and grips.
5. Ditto
They’ll all handle the same. There will be differences in compliance but the handling won’t change unless they’re so bendy that their shape effectively changes.
I remember changing from the stock stem and bars on my Levo to the current ones on there. There was a change in feel there - the stock stem was a skinny little 45mm thing, totally unsuitable for a 150mm ebike. The front end felt so much more positive pushing it into turns with a much stiffer stem resisting flex around its axis.
I recall discussing this with Keith @ Banshee and he said he preferred getting the grip height from bar rise more than stem spacers because like for like a higher rise bar is more compliant.
But it all ends up a muddle if you get compliance/flex/damping mixed up with geometry effects.
Posted : 29/01/2025 10:24 am
thols2, b33k34, b33k34 and 1 people reacted
 Gaah
Thanks for taking the time to explain your thoughts.
I get what you're saying. But we don't have super stiff steering components.
So I still think the leverage acting through the bar/stem clamp will make a slight difference to how those forces are shared when the front end is under various riding loads. Think weighting while cornering and preload as well as pulling up on the bars (bunny hops, manuals etc). I'd expect that slight difference to increase the longer the stem and more extreme the bar sweep. Nothing that's hugely significant while riding of course. Especially with sub 50mm stems and normal bar sweep. Numbers. But still.
Don't know what you do for a living or how well educated you are in physics etc. But I'm guessing neither of us have access to testing equipment to find a definitive answer for sure.
BMX flatland bars with zero sweep and a long stem on a long enough steerer to accept lots of spacers. Might be a workable DIY experiment. Far from ideal. Though. And still very subjective/difficult to judge what's actually going on without access to a lab with high tech stress measuring equipment.
Posted : 29/01/2025 2:47 pm
It won't. I spent a year studying engineering before I realized that I hated it and changed to a philosophy major. I think chiefgrooveguru actually works as an engineer. The path the forces take won't change the force acting on the steerer, it's just a matter of geometry. Sure, the amount of flex in the system might change, that's a different question.
Posted : 29/01/2025 3:03 pm
Flex can be quite substantial, You can get a 'feel' for it when bike packing if you have a rigidly mounted fork rack with a tall bag because the bars will move relative to it as the steerer / stem / bars all deflect.
Nowhere near enough to impact on handling though.
It's like watching a bike land in slow motion, yes the frame splays out slackening the head angle, but by nowhere near as much as the fork compressing steepens it.
I've also swapped the really rubbish OEM stem specialized use for a better one, it makes a huge difference to how the bike feels, but that's down to stiffness and the resulting feedback and confidence in the front wheel going where your brain tells it and it telling your brain there's grip.  It's not the same as handling.
Road bikes are a great testbed for this as there's a huge variety of bar shapes and quality. But they all (flared bars aside) fundamentally position your hands inline with the bike when holding the drops.  Swapping bars should make negligible difference, and it has no impact on the handling, but it can make a bike feel completely different swapping to some quality bars.
Posted : 29/01/2025 3:26 pm
sanername and sanername reacted
I have only just come to this thread and I am not an engineer or mathematician.
From my admittedly limited and amateur understanding - if you have a backwards swept bar with no rise (I ride one), with back sweep equal to stem length does  it not remove the impact of stem length?
Posted : 29/01/2025 4:44 pm
“…Don’t know what you do for a living or how well educated you are in physics etc.”
I did a mechanical engineering degree and after a diversion through some sales and financial services stuff accidentally started what’s become an audio equipment manufacturer (and can be found on YouTube waving my hands about whilst talking and playing bass, explaining/demoing physics and concepts and gear etc)
“I get what you’re saying. But we don’t have super stiff steering components…
When we’re looking at bike steering, we’re looking at a system where we’ve got force inputs at our hands and a reaction force from the front contact patch. Both of those generate a torque around the steering axis. Even at peak load (turning hard under a compression) there’s relatively limited shear force at the tyre to rotate the steering, not enough to change the geometry of the steering assembly.
There are a lot of other forces going through the front wheel and fork and bars but they generate minimal net torque around the steering axis so they won’t be able to distort the steering geometry to a significant degree.
What will happen in all these systems are higher frequency vibrations and resonances but they won’t change steering behaviour.
I suppose what I’m trying to say is that from the perspective of steering geometry and applied torques, we DO have super stiff steering components. In terms of flex in other directions the steering components do vary in stiffness and that affects the ride feel especially for lighter (too harsh) or heavier/stronger/faster (too flexy) riders.
“It’s like watching a bike land in slow motion, yes the frame splays out slackening the head angle, but by nowhere near as much as the fork compressing steepens it.”
I’ve been trying to figure that out from the huck to flat slo-mo videos on pinkbike. I think the frame isn’t bending much at all, it’s actually the fork itself bending, mostly at the steerer:crown:stanchions junction. So I think that the compressing fork is steepening the head angle (on a hardtail) whilst the bending fork is increasing the offset. (Despite that I enjoy using lots of the travel on my 160mm hardtail!)
Posted : 29/01/2025 7:25 pm
From my admittedly limited and amateur understanding – if you have a backwards swept bar with no rise (I ride one), with back sweep equal to stem length does it not remove the impact of stem length?
Doesn't it introduce flex?
Anyway, I've been meaning to try to throw a spanner in the works by muttering something about seatless competition trials bikes - with their ridiculously long stems.
Posted : 29/01/2025 7:45 pm
I’ve got my big bike back (Hope V4s went off for a factory refurb after 6 years of use), so I thought I’d compare the bar/stem set-ups on both.
So Moxie and my Levo have essentially the same geometry at sag, except the Levo has 20mm less reach and 20mm more chainstay, and the seat angle is slacker so the ETT is about the same.
Both have 50mm zero rise stems, and much the same stack and spacers. And 40mm rise 760mm wide FatBar Lites, which is one of the least swept bars you can buy (7 deg).
Running a straight edge between the centres of each grip, it passes 25mm in front of the centre of the steerer tube on the Levo and 35mm in front on the Moxie. That’s purely due to my preference in bar rotation on the two bikes, nothing else has changed. That’s the number I’d call Effective Stem Length.
Most bars have more backsweep than Renthals and obviously wider bars increase that setback more, so with 35mm stems you can end up near zero ESL.
Posted : 30/01/2025 12:38 pm
Gaah, thols2, b33k34 and 5 people reacted
Doesn’t it introduce flex?
Unless a different material is chosen or additional material added to increase stiffness - I believe that with increased stem length, flex would increase.
Posted : 30/01/2025 4:28 pm
sirromj and sirromj reacted
Coming back to this at this page ... I'm glad someone mentioned L-shaped cranks.
The other point to mention is that a bike can ride really well wth your hands well behind the steerer rather than in front. When you think about how you steer a slack HTA MTB with a tendancy to opposite lock as a bike slides in a corner, or how pulling up/back is such a big part of MTB handling.. maybe +ve length stems on MTBs are just another roadie carry-over waiting to be killed off.
Posted : 30/01/2025 5:46 pm
"The other point to mention is that a bike can ride really well wth your hands well behind the steerer rather than in front. When you think about how you steer a slack HTA MTB with a tendancy to opposite lock as a bike slides in a corner, or how pulling up/back is such a big part of MTB handling.. maybe +ve length stems on MTBs are just another roadie carry-over waiting to be killed off."
The thing I always notice as ESL approaches zero or goes negative is that weighting the bars, either consciously or accidentally, no longer has a stabilising effect. With some ESL then when you push on or load the bars, the force required to turn the steering increases. Personally I like how as I get my weight onto the bars in a corner, it gets harder to turn the bike, so you're adding stability. Likewise, if I hit a big bump, brake hard, or land front heavy, that weight transfer tends to straighten the bars rather than turn them.
Maybe that's why I have the bars rotated more forward on the hardtail and more backwards on the ebike - because the latter is inherent very stable (heavy and full-sus) so it doesn't need as much steering self-centering?
Posted : 31/01/2025 12:33 pm
Sounds right, as we push down we're also pushing forward and positive stem/ESL has some tiller effect - it should work the other way with a negative length, stability and centring when pulling back off a drop or jumps. More important that some feedback is there and you're used to it though.
Posted : 31/01/2025 12:49 pm
“it should work the other way with a negative length, stability and centring when pulling back off a drop or jumps.”
I’m far from brilliant at jumps and drops but I don’t think I tend to pull back much, if at all - it’s much more of a preload, pop, push thing. But even if there were a pull that’s usually a far more controlled state, where you’re dictating what you want the bike to do, rather than reacting to what’s coming at you.
Posted : 31/01/2025 10:47 pm
I know what you mean, it's more about a weight shift back - what I mean is when your input at the bar is in a rear upward direction, not forward. Perhaps not enough or not often enough to mean any stability from a negative stem/ESL is worth much.
Posted : 03/02/2025 8:05 am
 LAT
Below is a link to Peter verdone’s starfighter  it has a one piece bar and stem thst mounts the bar behind the steerer.
I’d post a picture, but I can’t remember how
Posted : 03/02/2025 9:16 pm
