I [s]have[/s] had Yokozuna reaction brake and gear cables on my old tripster frame..
The v2 frame has internal routing, so need new (longer) cables...
It seems yokozuna are no longer easily available, or are £70 a set :-/
What's jagwire like? Any others?
DrP
I use Odyssey linear slic cables.
The Jagwire stuff is great, but last time I looked it was only available in a rather spendy set with inners and faffy packaging and whatnot, getting hold of just the outer involved ordering from the USA. Also, if you do go for the spendy cable set, make sure you get the right one, the normal road one only has enough outer for rim brakes, I think you need the 'Pro' one or something for discs. Check carefully before ordering at any rate.
Jagwires are good, ime.
