What’s the benefit ...
[Closed] What’s the benefit of carbon rims??
 DrP
[#9910634]
I was poking around at replacing the ZTR Crests on my Singlespeed...
PLaying around on the light bicycle website I see the standard XC 29er rims are 360gm per rim...the lightweight ones are 280gm..
”THat’s light I thought...” and then googled what my crests are... 380gm!
SO unless I drop a LOAD of money on the lightweight ones (An extra 130$ per rim it sems) i’m Not gaining much lightness....
Or am I missing something?
DrP
Posted : 25/03/2018 8:51 pm
Stronger and stiffer.
Posted : 25/03/2018 8:53 pm
Bling, innit plus you get to taste the very expensive kool-aid...
Posted : 25/03/2018 9:07 pm
Stronger (apparently) and a very fine way of shedding pounds (from your wallet)
Posted : 25/03/2018 9:09 pm
Viagra & steroids & Xenical / Picolax 👍😀
Posted : 25/03/2018 9:10 pm
Seen a Reynolds carbon rim explode dropping into Treacherous Puddle in Chopwell.  Made a hell of a bang, and totalled a relatively expensive piece of kit which none of us who normally wide it have had a problem with.
If I wasn't paying for them I'd try them, but when a Flow Mk3 is <£70, it's a no-brainer.
Posted : 25/03/2018 9:25 pm
The lightness/stiffness advantage increases as the rims get wider.
Posted : 25/03/2018 10:02 pm
Posted : 25/03/2018 10:06 pm
I replaced my Crests on my ss with LB 30mm wide ones.The rims were the same weight as the crests but as wide as flows (they ended up a lighter build cos of hubs/spokes).
I used to think the noodly handling of my El Mar was just me being fat and SIDS being weedy.Notsomuch.........it was my alarmingly bendy wheels!! It actually took me a while to adjust to the stiffer wheels as I'd either run wide over bumps or overturn (especially loading up in berms).
And now I can run sub 20psi with out getting all rolly (if I still actually rode that is).
Posted : 25/03/2018 10:12 pm
I broke a 1 yr old rear Giant XCR 1 the other week and didn’t even notice it, regular xc riding and no jumping. Even after a healthy discount the replacement was over £350.  If I break another it’ll be a pair of Mavic XA Elite or Hope’s.....
Posted : 25/03/2018 10:16 pm
The narrower ones are similar to crests. But the wider ones are much much lighter than any allow rims.
There's also a 280g super light LB rim with a 95kg rider limit!
Posted : 25/03/2018 10:44 pm
It means you can show people you don't know that you spend a lot of money on your toys.
Posted : 25/03/2018 10:56 pm
Also, the LB ones aren't that much extra over a normal wheel build. They certainly aren't £1500 like off the shelf wheelsets, which is a pisstake.
Posted : 25/03/2018 10:59 pm
Willy waving rights innit?
Ok. There may be a weight/strength gain. But we're talking F1 levels of cost/gains here I think. A klutz like myself probably wouldn't notice any benefits, but would notice the lightness of my wallet.
Posted : 25/03/2018 11:12 pm
But we’re talking F1 levels of cost/gains here I think.
Not really.  The rims are about £120 each.  A pair of Hope Pro 4 hubs is what, £190?  £40 for Sapim Race spokes, that's around £500 with the price of building.  That sort of price for a wheelset gets tossed around quite casually on here and on the website.
Posted : 25/03/2018 11:42 pm
Can you post a link to a decent modern carbon MTB wheelset for £500 please.
Posted : 25/03/2018 11:56 pm
Awaits with baited breath...
Posted : 26/03/2018 1:00 am
why would you use heavy hope hubs with carbon rims? ah yes stiffness.
Posted : 26/03/2018 1:10 am
I can live with a carbon frame and carbon bars but carbon wheels scare the pants off me.Lol
Posted : 26/03/2018 1:18 am
100g in the rim is a fairly big difference tbh,if you think about it another way, would you want to swap your Crests for a 480g rim, like say a KOM i29?
But it does get fairly hard to beat out the last few grams, especially when the alu kit is already light and making sacrifices of strength like a Crest- there's simply minimum volumes of material and minimum strengths that you run into. For me it's heavier use where carbon worked out better, though not everyone will agree- I have the 390g 29er LB rims on my Remedy, there's no 395g alu rim that I'd put on that bike. If I went alu it'd probably be an EX471, at 530g apiece.
Now some people would say, 140g a wheel isn't a difference worth worrying about. And those folks obviously won't be interested. I have a heavy duty wheelset with 560g alu rims (not so much because they're that much stronger than my carbons, mostly because they're cheaper- downhilling, rims no matter how strong are in the firing line and I'd much sooner damage a £45 rim!) and it makes a big difference to me.
Wheels strength is always hard to judge- strength and toughness are fairly separate, the wheel needs to survive whatever everyday hits it'll take but toughness really comes into it with exceptions- casing on a rock edge, flatting a tyre and riding it out on the flat. Some tyres are strong but not tough (Flow Ex was a good example) And the rider makes a big difference to how many times you need tough- how much tyre they use, how tidy they are, how they ride and where, pressures etc.
For me, it comes down to what it took for me to break my original LB rim, a 360g 26er. I wrecked 2 middleweight alu rims on that bike, then replaced with the LB and it outlived those 2 alu rims combined by about 2 years. I eventually cracked it with a big stupid mistake which realistically could have damaged any wheel. My 29er ones have given good enough service that if I was to break one tomorrow I'd say, fair enough- especially if it was some riding error like that one was. (I just saw the price they are now and tbh, I'm not totally sure I'd buy them again! But only because of the 50% price increase)
Posted : 26/03/2018 1:37 am
I'm lucky if I spend £500 on a bike, never mind wheels for a bike!   I expect cost will come down in time though?
Posted : 26/03/2018 10:13 am
Think you misread my post. I'm saying that if you buy LB rims and build them up you can get a wheelset for in the region of £500 ish. That is much cheaper than off the shelf carbon wheelsets.
Posted : 26/03/2018 10:30 am
@howsyourdad1
If you look at weight/cost, it becomes a bit balanced.  For a wide plus size rim, the WTB scraper (£70) weighs 650g, a cheap(ish) carbon one under 500g, that is 250g difference, for ~ £200.  Just over 1g saved per extra £ spent very roughly speaking.
By contrast, a DT 240s 6-bolt weighs 240 g and costs £230,  a decent Novatec hub a tad under 340 g and costs £60 or so, saving more than a gramme per pound saving.  (On front hubs the weight diffs are way lower, but so are the price diffs so a carbon rimmed front wheel is going to be expensiver whatever hub you use.)
So at least on the rear, budget hub/carbon rim is a serious option.  But you would probably want to go carbon on the front as well, and that would be expensiver however you did it.
Posted : 26/03/2018 10:37 am
ok cheers. I have stuck with aluminium on dt 240s. cost is the main reason,  but also yeah, one wheelset/one that I need to be working. lots of people have said to me ah yes buy 3 or 4 rims from LB so when you break one you have a spare to hand. All good but  = more cost.
if I was to get carbon I would save up and do the santa cruz warranty thing
Posted : 26/03/2018 10:55 am
You'd likely be able to build the carbon ones with less (28) spokes, so that might save another 30-40g (20g each end). The carbon ones can be ran tubeless at higher pressure.  I've had a set running at 70psi for over a year.
ICAN 650B XC Bike Hookless Rim Carbon Mountain Bike Wheelset 30mm Width Front 15x100mm Rear 12x142mm Shimano Freehub https://www.amazon.co.uk/dp/B072L8233Q/ref=cm_sw_r_cp_apa_SBlUAbWP9E56R425 icann on Amazon
Posted : 26/03/2018 11:01 am
I've had a good think about it and IMHO it's "nice things are nice to have".
For your average Muggle rider like us it's not going to be a massive performance benefit, yeah they'll 'feel' better, but I've seen a load of rabid tech consumers be given an 4 year old smart phone in fancy case and told it's a the latest greatest thing and they all thought it was amazing.
They *should* be lighter and stronger than an Alu equivalent, but as so many people have already stated, it's actually pretty easy to find a lighter Alu rim and they're not exactly exploding on every cased jump or badly ridden rock garden. No I think the only stated benefit is they're stiffer - but then in the early days of Enve rims some riders were complaining about a rough ride because they were too stiff so who knows.
Posted : 26/03/2018 12:25 pm
 it’s actually pretty easy to find a lighter Alu rim
Not above 30mm it isn't.  And below that there's only one rim I know of that's comparable.  What light alloy rims are you thinking of?
icann on Amazon
He said decent not bargain bin knock-off!
The WTB scraper mentioned above in 29 x 45mm costs £73 weighs an astonishing 725g!  The LB plus rim is 490g and costs $210 or about £150, import duty and shipping notwithstanding.  So you could be saving a pound on your wheels for approximately £150 extra or thereabouts.
That's a pretty damn good upgrade to your 29+ bike for the money, IMO.
Posted : 26/03/2018 12:38 pm
So what hubs are the weight weenie choice these days?
Posted : 26/03/2018 12:41 pm
Re. the OP, as with anything it's diminishing returns. A good alloy wheel will be close to a much more expensive carbon one, but if you want that weight saving you have to go carbon.
Whether its worth it (including the bend vs break factor) is up to you. If I were to get a carbon rimmed wheel set, it would probably only come out for XC races.
Posted : 26/03/2018 12:52 pm
Hmm dodgy maths alert. Scrapers are (claimed) 550g for i40 and 650g (i45). LB carbon plus rims are (claimed) 480g for 40mm internal and (strangely) 450g for 45mm internal. So best case 200g.
Edit those are 650b+ weights
Posted : 26/03/2018 1:05 pm
"Molgrips"
You're looking at nearly £500 to land your rims (AM/EN728) at your front door all taxes paid add Hubs, spokes etc.  My Hope build will be £760 at present exchange rates - not £500.
Still less than half the price of new SC Reserve rims albeit without the unconditional guarantee, which may be worth the extra if you break rims regularly.
Oh, nearly forgot;
DT Swiss 240's for the weight weenies.
Posted : 26/03/2018 1:16 pm
 DrP
A good variety of replies 🙂
I was also looking at some carbon rims for my hardcore hardtail..but....although that WOULD offer the better wieight saving as they'd be wider rims, i'd be more concerned that i'd thrash that bike more, and thus worry about breaking the rims...
I was just surprised that there isn't a huge weight benefit over my current CX rims....
However, I do also buy into the 'nice things are nice' philosophy...
If i were to get rims, it's be a straight swap, so i wouldn'#t be buying new hubs on top (Hope pro2 evos currently)...
Food for thought
DrP
Posted : 26/03/2018 1:29 pm
I thought I had already done so, but in case I hadn't, I hereby apologise unreservedly for my arithmetical error.
Posted : 26/03/2018 1:37 pm
 You’re looking at nearly £500 to land your rims (AM/EN728) at your front door all taxes paid add Hubs, spokes etc.  My Hope build will be £760 at present exchange rates – not £500.
Which is why I ended up getting mine from Blue Flow Wheels rather than messing around getting them from China. They start at £679.
Light bike wheels are only around 600 quid aren't they?
Posted : 26/03/2018 1:41 pm
Wish I'd have brought some salt and vinegar for all these shoulder chips 🙂
I've had all sorts of wheels from the cheapest 26" to SC Reserve 29ers. The Reserves feel and ride extremely well! The thing is, as I've progressed as a rider, I've had more expensive upgrades, so it's hard to compare.
I just like the warranty and the fact that they look nice. Them making the bike fun to ride is a plus too. The cheap Superstar AMX 26" were great on my Voodoo Hoodoo! I suspect I wasn't exactly stressing them to the limits though back then 🙂
What tax and shipping did you pay?  £750 is still much much cheaper than off the shelf carbon wheels though.
Posted : 26/03/2018 2:14 pm
Import duty and VAT here.
Some suppliers enclose a low value invoice with the goods.  I guess it is between you and your conscience whether you declare what you actually paid.
Posted : 26/03/2018 2:43 pm
What was the actual cost though?  Duty varies widely.
EDIT seems to be 4.7%.
That makes the 45mm rim about £190.  So £250 extra on your wheel build for a 450g saving.
Posted : 26/03/2018 2:48 pm
I wouldn't go carbon on my cx on the basis that's the one bike I continually crash in new and unusual ways - I'm sold on cheap there as I'll be last regardless.
ANyone actually got those ICAN wheels? Is 30mm enough for 2.8 tyres to be sensible shapes?
Posted : 26/03/2018 2:59 pm
If you ride aggressively, occasionally pinch flat tubeless tyres and want to enjoy hammering down rocky trails without worrying about your rims making it out alive then stick with alloy.
If you want to do none of the above then get carbon rims and enjoy the slight increase in stiffness and slight reduction in weight.
Posted : 26/03/2018 3:48 pm
CRC / Wiggle are selling carbon rimmed road wheels for ~£500 using their Prime brand. I can imagine that if they expanded into MTB wheels costs would be similar so its not inconceivable we'll soon be seeing £500 pre-built wheelsets with proper warrenty etc.
Posted : 26/03/2018 3:59 pm
We've established it can be a pretty signifiant reduction.
Posted : 26/03/2018 5:30 pm
I've got carbon wheels on my big bouncy bike. Was concerned about breaking them then saw Danny M trying to break a set. Not so worried now.
Posted : 26/03/2018 5:36 pm
