whats that alcohol ...
[Closed] whats that alcohol called that's great for degreasing?
looking for something to clean up rims, cassettes general degreasing
seem to remember people buying some kind of alcohol from e-bay in big bottles
Posted : 20/04/2017 7:19 am
IPA
Isopropyl Alcohol, not India Pale Ale
Posted : 20/04/2017 7:20 am
Stella.
Posted : 20/04/2017 7:25 am
I believe this is what you're looking for
Posted : 20/04/2017 7:27 am
 poah
propan-2-ol
Posted : 20/04/2017 7:29 am
I wouldn't say it's a great degreaser - good for wipe-downs but isn't really a solvent for grease (esp if you really mean [b]grease[/b]).
Depends what you're tyring to achieve. Rubbing road kack off rims, probably good; rinsing a cassette and magically removing all grease (again, depending what you use,I guess), little chance
Posted : 20/04/2017 7:34 am
Yeah, what scaredypants says. It's good for rims and disc brakes as it pretty much all evaporates but less good as an actual degreaser.
Posted : 20/04/2017 7:43 am
As above. for 'degreasing' your drive train I'd suggest meths or white spirit would be better.
Personally I use white spirit, and re-cycle it through a coffee filter.
Posted : 20/04/2017 7:48 am
Paraffin as a degreaser, if yer really pernickety, IPA to remove any paraffin residue.
Posted : 20/04/2017 7:49 am
Not sure what IPA does to rubber though - I seem to recall it ate my tyre sidewall....
Posted : 20/04/2017 7:54 am
Bacardi 151 rum. 75.5% enjoy.
Posted : 20/04/2017 8:02 am
 poah
use wd40 as a degreaser
Posted : 20/04/2017 8:09 am
Personally wouldn't use it to clean drive train, I use below 5 l for a tenner and dilute it up to 50:1, I've had it about 2 year and there is still 1/4 left
http://www.screwfix.com/p/swarfega-oil-grease-remover-5ltr/20817?kpid=20817&cm_mmc=Google-_-Product%2520Listing%2520Ads-_-Sales%2520Tracking-_-sales%2520tracking%2520url&gclid=CNy8u-nKstMCFZIaGwodw6sAjA&gclsrc=aw.ds&dclid=CNm_2-nKstMCFdUB0wod9qMJig
Posted : 20/04/2017 8:13 am
I think you are covered above. FWIW I would use white spirit for degreasing. Non polar solvents are better - there is minimal contaminants in DIY white spirit so I wouldn't bother with any further cleaning. IPA is good for rims but use sparingly on a cloth as it will damage tyres if used excessively.
If everything is in situ then the bike shop degreasers do work really well, apply with a cheap paint brush. Alternatively for rim brakes try an enamel rubber on the rim to remove contamination. Don't forget the blocks, remove hardlumps of grit and metal, give a good scrub with a scourer.
Posted : 20/04/2017 8:52 am
BlobOnAStick - Member
Should be fine on tyres, not an aggressive solvent. Quite often used by track riders to clean dirty/new tubs to prevent slipping down the track.
Posted : 20/04/2017 9:11 am
Has no effect on rubber IME - used it extensively for clean and inspect on aircraft engine parts, including rubber bellows.
Posted : 20/04/2017 10:53 am
