Continental Mountai...
[Closed] Continental Mountain King 2.4
[#375545]
http://www.chainreactioncycles.com/Models.aspx?ModelID=24234
Will it fit in a geared Inbred frame and still leave clearance?
Posted : 09/03/2009 7:44 pm
If anything like my 2.4 Rubber Queen, they're mahoosive!
Posted : 09/03/2009 7:57 pm
They rub on my 575 when its weighted and cranked over. Oh and then they let go. They're crap in the dry loose stuff.
Posted : 09/03/2009 8:35 pm
Fit in my Chameleon with room to spare. At the right pressure they grip.
Posted : 09/03/2009 9:00 pm
Sidewalls give way a bit too easily for my liking...
Posted : 09/03/2009 9:38 pm
 Del
almost certain they will fit.
Posted : 09/03/2009 9:40 pm
I have had none of the above problems. Couldn't comment on their performance on rock but anything from 20-30psi in dry through to full mud and they've been excellent.
They should fit in an INbred they aren't THAT big I think mine measure up correctly once inflated. Fit in a Simple with acres of clearance.
Posted : 09/03/2009 9:42 pm
 rs
seemed quite small to me for a 2.4.
Posted : 09/03/2009 9:44 pm
When inflated to approx 30psi
61mm knob to knob
55mm across the carcass
61mm is 2.4inches.
Posted : 09/03/2009 9:51 pm
They fit in my inbred summer season. I don't like them on wet rock/roots, but on med/hard pack dirt they're a very solid choice.
Posted : 09/03/2009 9:53 pm
Thanks everyone. Will measure the Cinder 2.25 I've had in there before once I've fixed the puncture and scraped off the doggie doo doos and compare.
Posted : 09/03/2009 10:14 pm
I test rode a Lapierre Zesty with them on at Whinlatter and thought they were excellent at 32psi front 35psi rear. I weigh 164 lbs. Awesome on rock. They were the tubeless versions.
Posted : 09/03/2009 10:16 pm
