what tools do I nee...
[Closed] what tools do I need to fit this crank & bb?
[#3543033]
what do I need to fit this: http://www.planet-x-bikes.co.uk/i/q/CSFSGCC/fsa_gossamer_cyclo_cross_chainset_megaexo
Posted : 09/01/2012 11:39 am
Looks like a std shimano type BB etc
so
5mm allan key
Shimano HT2 bearing cup spanner or socket
should do it, some may add torque wrench and maybe even BB facing tool
Posted : 09/01/2012 11:44 am
which one???
http://www.merlincycles.co.uk/Bike+Shop/Workshop++Tools/Tools/Tools+-+Workshop/list.htm?pl=100
Posted : 09/01/2012 1:21 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=36381&utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom ]This one, in case FSA and Shimano don't use the same type of cup?[/url]
Posted : 09/01/2012 1:32 pm
cheers mate, how tight should it be?
Posted : 09/01/2012 1:45 pm
Mrs j has a (different) fsa crankset on her road bike: the torque tightnesses are etched on the cups and the crank.
Posted : 09/01/2012 1:56 pm
I use "pretty damn tight" on my scale of tightness, a bit less on alu or Ti. It's not a precise measure, so you may be better off using a torque wrench if you've got one! The crank clamp bolts are "not all that tight" on the same scale.
Posted : 09/01/2012 2:13 pm
I've got that tool, it does my FSA Gossamer and HT11.
Posted : 09/01/2012 2:23 pm
how can I use a torque wrench for this spanner?
do I need a tool to fit & tighten the crank too?
Posted : 09/01/2012 2:32 pm
I have two sets of FSA cranks and they both require the use of an "FSA pin tool" to tighen and remove the retaining crank bolt insert. £54.99 from CRC or borrow one??
Posted : 09/01/2012 3:19 pm
think I'll go to my lbs
cheers chaps!
Posted : 09/01/2012 3:29 pm
