...are Rockshox Maxles made out of?
Warm brie.
does it go well with the ham you fists are made of 😉
So close!
Halloumi. Always Halloumi.
Em-metal
Like it
A fairly rare and expensive one in case you haven't seen the price to replace it yet 😉
I've got another Maxle in it. Got it for a good price, but it still wasn't cheap.
If this one folds up the same way I'll replace it with a bolt through.
The collar bit on the Maxle is really very thin.
I use the bolt in Maxle Stealth and use a torques wrench. I also have a healthy respect for aluminium screw threads.
Well, you should have replaced it with either a Maxle Ultimate or a bolt through.
Found out about the bolt through after I'd sorted the new Maxle.
Can't brielieve how weak they are..
Rick otter.
Replaced one under warranty not long back.
I guess if they made them stronger, we'd moan that they weren't lighter...
The LBS have sent mine back. Hopefully I'll get a refund under warranty. It looked like I had put it through a very large pencil sharpener.
If they made them stronger I'd be a lot happier and would be less likely to moan about them on the internet.
Roque[s]fort[/s]shox
Talleg-your forks- igo.
Sorry not sorry
no point having something so light it is not effective at the task it is designed to do.I guess if they made them stronger, we'd moan that they weren't lighter...
Eh Damn !
[i]no point having something so light it is not effective at the task it is designed to do. [/i]
No whey!
How about...
Thread-less-ter
Thank you, thank you very much (takes a bow)
