What rotor size doe...
[Closed] What rotor size does a 2013 Lyrik take without adaptor?
Or to put it another way, what adaptor do I need to run a 203mm disk?
Posted : 30/08/2014 2:14 pm
203 Post to Post adapter.
The Lyrik will be a 160 Post without adapter. Unless they've changed it for 2013 but as I understand it most forks are 160 Post (if they're not IS).
Just to check, definitely 203? Only ask if you have something like a new Avid like Trail or Guide as they've changed to 200mm and that needs a 40mm Post adapter instead (but does thankfully do away with CPS washers). Though I guess you can use a 203 rotor with 203 adapter with them anyway.
Posted : 30/08/2014 2:23 pm
Deffo 203, Hope saw rotors (v4 brakes). Must be as my previous fork only took 203mm. Thanks deadkenny, that's what I thought. Just wanted to check that they don't take a 180 as standard or something.
Posted : 30/08/2014 2:34 pm
