What Psi are you ru...
[Closed] What Psi are you running in your Camber Evo? (Or similar FS 29er)
[#7127273]
I've tried 29/30 front and rear and it felt good, nice and grippy. Also had them at 38/40 and the front pinged off rocks a bit too much. New to 29ers.
Posted : 12/06/2015 6:47 pm
I have a spectral 29er, I'm a big fella - 6'2" and 16 stone, 17 front, 21 rear. Shorty front, smorgasbord rear, both tubeless. Also have a Yeti SB66, run that slightly harder, 20F, 25R, but that's generally cos it's used for lakes etc.
Posted : 12/06/2015 7:10 pm
Rider weight, terrain and tyre volume are more relevant than bike.
Sounds like 29/30 worked for you?
Posted : 12/06/2015 7:20 pm
Yeah it felt pretty good but this whole 29er thing is new to me, sounds like as low as you can go is the way forward! I do use a few roads to connect the good bits so I like to keep rolling resistance to a minimum on the back, running a small block eight on my heckler but can't find it in a 2.3 29er? Guess that's the trouble with big wheels there just isn't the choice of tyres. I'll keep it at around 30 and see how it goes. Thanks for the input!
Posted : 12/06/2015 10:59 pm
 kd48
I run my Camber Evo tubeless with a Conti Trail King 2.2 up front and a Mountain King 2 on the back at 20 & 25psi respectively. I'm about 80kg and ride lots of rooty, loamy stuff, I put 2 or so more in each for trail centre stuff. Hope that helps.
Posted : 12/06/2015 11:22 pm
Thing is, I used to run 38 and 40 psi in my 26" wheeled heckler. I set it up to roll as fast as possible and still corner and just set the suspension to absorb most of the bumps. Brilliant bike. Camber is definitely a different animal
Posted : 13/06/2015 6:55 am
Kd48 what did you think of the tyres that were on there?
Posted : 13/06/2015 6:57 am
