What POS headset is...
[Closed] What POS headset is this?
[#5810971]
So I have a voodoo bokor hardtail 26" And I wanted to clean out headset and give it some new grease. I take out the fork and I see the bearings are integrated into the headset cups. How do I take the bearings out for a service? And as for that matter, anyone here ride a bokor and has upgraded their headset? thanks!
Posted : 31/12/2013 3:12 pm
The original headset in the bokor appears to be water soluble. The "summer/autumn" of 2012 was enough to see it decay into a mess of iron oxide, far, far quicker than any headset, peddle or axle I have known.
IIRC the headset sizing is nothing obtuse - i think i fitted a cheap Richey unit that used sealed bearings, so if you decide to replace the original, you should be fine. The Richey one has lasted much longer.
Posted : 31/12/2013 3:29 pm
Yes, I intend to replace most of the bearings.
Posted : 31/12/2013 3:31 pm
I'd just buy a cheap headset with proper sealed bearings and fit that.
I've never had any success with more open designs however much maintenance they've had.
Posted : 31/12/2013 3:32 pm
FSA Orbit XL11 is the usual answer to any headset issues. Sealed cartridge bearings, bombproof and can be had for about £25. Fit it and forget it!
I've fitted one as a default to pretty much every bike I've owned. If you look for headset advice on here, it seems a lot of other folk do too
Posted : 31/12/2013 3:41 pm
Will that fit into the Bokor headtube?
Posted : 31/12/2013 4:21 pm
Is the head tube 1 1/8", or is it one of those fancy new-fangled tapered ones.
I've just had a quick look on the Halfords site and it looks like a standard 1 1/8" job. In which case, this seems like a damn good deal at [url= http://www.on-one.co.uk/i/q/HSFSOMX/fsa_orbit_mx_headset ]On one[/url]
In the pimpy colour of your choice 🙂
Posted : 31/12/2013 4:51 pm
Awesome, thanks binners, I'll probably go with the red colour 😀
Posted : 31/12/2013 5:26 pm
