which I have looked in the manual for but does nto have a pressure chart atall.
I have already pumped approx 215-220psi in there and with propedal off completely, even with it on full pro pedal, it's still soft on preload/bit too much sag.
Or is that I have not ridden a full sus since 2006 and been on a hardtail 😆
SO what maximum air pressure is ok for the 2006 High Volume RP3 Fox shock?
thankyou.
300psi
thankyou LoCo, just I had a bad experience once with a 2006 float r where it stuck down, - thought it was because I put too much air in the chamber but do somewhat seem to remember something Mojo stated about dodgy air seals being the culprit.
Will go pump up now then, no time like the present for a bit of weekend warring. 😛
