Simple question really....
I have one of these;
And I've just bought one of these;
And I need to do this;
I've done some experiments with bike lights, but the battery pack is too big and heavy, I need to get at least 5 minutes flight time, and keep the beam consistently on the ground, regardless of what the quadcopter is doing...
Can the STW hive mind recommend me a small yet powerful headtorch ideally running on max 2 x 18650 (or that I can patch into the 11.1v phantom powerpack- would this blow up a cree t6??) that I can bodge mount onto the rather small surface area of the gimbal?
Fairly random request I know, but if you are having a slow Wednesday, please feel free to pitch in with ideas 🙂
Just don't ask why......
Why?
clubber - Member
Why?
Tedious work stuff...
[img] https://lh5.googleusercontent.com/wYbUZggKGMd1CPr5uDArku0ITu-wC1sXfzB2Wy0OC-le=w883-h588-no [/img]
Cheers Dr P- can you make any up/down adjustment on that?
Joystick is lightweight but not especially bright. OTOH most of the brighter (cheap) torches will be a bit heavier.
Hi Joe
What sort of beam IE spot or flood and what range do you need
I could make a single Led and driver for you to wire into the copters battery . which led depends on the range and beam .
then you dont need to carry heavy batteries .
Hi Trout!
Thought this might tickle your fancy...
Would need to be about 2.5 m wide spot at 10-20 m away, my experiments have been with aldi zoomable torches, they've been quite useful so I can zoom to fit the available space on different sites.
Northwind, I think you're right. Quick ebay search brings up this;
[url= http://www.ebay.co.uk/itm/1800-Lumen-Zoomable-CREE-XM-L-T6-LED-18650-Zoom-HeadLamp-HeadLight-Charger-/160946857324?pt=UK_SportsLeisure_Camping_LightsLanternsTorches&hash=item25792e256c ]1800 zoomable headtorch[/url]
But don't know if I would blow it up plugging it into 11.1v
If that zoomable head torch is right then it would be a simple job to swap out the driver for one you could run from the copters battery
thats quite a tight spotlight at 20 metres
Tedious work stuff is drawing up a document analysing risks in the crappy software system I'm dealing with. Sticking torches on a quadcopter isn't.
Thanks Trout-
Yes, as I said, having a variable beam is the most useful.
Talk to me about different drivers? Where do you find them?
Found pictures from our week in Germany again the other day- cracking bit of riding. Still miss that Salami and Weissbier...
I have no idea, but I'd like to see the results some time!
@flyingmonkeycorps- once I've got it up and running I'll post some footage of my experiments.. suffice to say it will involve me running around in the dark with a cordless smoke machine in one hand and the remote control to £700 of flying kit in the other...
You know the drill 🙂
Just going to have a rummage in the tip/Garage and see what I have in stock .
got most drivers so should have one that will do the job .
Going to Bavaria with the Germans in September you welcome to come along
may have a space in the van as expecting one of the lads to drop out .
We need to sync one of our trips down South with one of your performances. That or you should come up North again!
@trout- tempting, let me know the dates when you have them. Give me a shout when you've had a rummage in the garage- my email address is the same.
@flyingmonkeycorps- in Dorset end of April (for some reason I remember you having some links there?) but yes, may stray back oop north sometime soon...
You could knock up something using a couple of P60 drop in modules wired to the existing battery.
I'd image a P60 drop in would only be 60 ish grams.
