Horst link 5 spot, 2005 with 5.3 inch travel. large frame.
Assume I will for a 130ml fork with the correct axle to crown height 500mm.
Do you think 110mm is too long, what do 5 spot owners think?
ive got a 90mm on mine but i guess it depends on how you like it to fit and feel and how tall you are etc
50mm on mine, recently changed from 70mm as an experiment. Keeping it on - handles great and can now do (small) jumps without stacking too often!
Its such a great all round frame I think I'll be OK with 110 to start- can always change later.
90mm on mine. Suggest you look on the Turner section of the MTBR forum for ideas on setup. I have just changed from Pace RC40XCAMs (130mm) to Pike 454s (140mm).
I've got an 04 5-Spot in large and run a 110mm.I'am 6'2'' with long arms though!
Thanx Max
I thought there was no difference between HL and TNT..... Sorry I've no idea what stem length you need for your 'HL' Turner. Everyones measurements are different.
I wanted to make sure that it didn't slow the steering too much with a standard 130ml fork, I know everyone's measurements are different!
