Rock shox reba - bi...
[Closed] Rock shox reba - bit of oil leakage OK?
[#390841]
Took my new REBA SL's out last weekend for a first ride, opened the shed this morning and noticed a fair size stain of what 'I presume is oil under the left leg (with the air valve) So here's hoping thats allowed or should they be sent back to the shop?
Only issue their is that they are OEM so no warranty I guess...
Also got numpty question -presuming that they are 100mm travel standard and the spacers reduce the travel to 80mm?
thanks
MC
Posted : 14/03/2009 10:11 pm
Don't know for sure about the Rebas, but Darts and Toras suffered with a batch of faulty damper cartridges that leaked oil into the lower leg and then all over the floor. Take them back, if it is the same fault it should be covered and isn't a big job to do.
Posted : 14/03/2009 10:44 pm
My 1st set of Rebas were faulty (always struggled to keep up with everyone on rocky descents etc).
No leaks though.
2nd set and I can leave people through the twists and do it at the last second with a stiff frame-racing -others will hit the tree following your lines. Obviously not in a trail friendly group.
Your Rebas shouldn't leak-take them back-the warranty is with the bike shop for a year unless stated at POS and when you paid with your credit card...
Posted : 15/03/2009 12:10 am
If it's just a little bit, then don't worry. mine do that, and others, too I hear, so it's normal. Mine work fine.
Posted : 15/03/2009 12:38 am
Stain on floor of shed was around 20cm diameter - bottom of leg was still wet - seems like its too much to me
MC
Posted : 15/03/2009 1:13 am
