What headset?
[Closed] What headset?
I recently fitted a Cane Creek Tank Jump on a second hand Chameleon with 2003 Marzocchi Z1 Drop Off with ETA travel lock-out. The ETA control lever hits the underside of the frame on full lock. Now I'm not known for my bar-spins or tail whips, but I am concerned that if I were to crash the ETA control may be damaged. I've unscrewed this and taken it off at the moment but also want to change the headset as it is showing some signs of wear.
The Cane Creek headset has a 12.8mm bottom stack height. My question is this, if I replace this with a Hope headset which has a bottom stack height of 14.1mm will this solve the problem?
Additionally I want to get a headset that will be reasonably good for the next two or three years. Would you recommend the Hope over the Chris King? The CK has a bottom stack height of 13.7mm but at £100.00 instead of £60.00 for the Hope one I'm undecided which to go for.
Someone also suggested putting a spacer underneath the crown race, anyone done this, is it safe?
Thanks
Posted : 27/09/2010 11:29 am
Bump
Posted : 27/09/2010 3:05 pm
Spacer = bad
chopping down the ETA lever until you've got just enough to work with = good
The ETA controls are smooth and easy to turn, so I'd go with a *ahem* tiny knob.
Posted : 27/09/2010 3:34 pm
Very pleased with my hope headset, you can also get a crown race for the Hope headset that gives an extra 3mm of clearance. Costs less than £10 and may give you the extra clearance you need.
Posted : 27/09/2010 3:42 pm
Hey,
Is that the standard Hope crown race or an extra large one? If so where did you find it?
Thanks
Posted : 27/09/2010 4:35 pm
 PJay
What about a [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=11258 ]Cane Creek Plus 5[/url]? I think that there are a number of headset with taller lower cups for just this eventuality (I think there's an On-One Smoothie too).
Posted : 27/09/2010 4:39 pm
Good call on the Plus 5, but the reviews on the seals are not so good. Some people talking of a high baseplate/crown race. Anyone know where to get these?
Posted : 27/09/2010 4:51 pm
There is some info on the hope website about the thicker crown race, it is not the standard one, should be available from your LBS
Posted : 27/09/2010 5:18 pm
+1 for Hope.
Posted : 27/09/2010 5:19 pm
Hey,
I looked on the Hope site and couldn't get any info. Do you have a link?
Thanks
Posted : 27/09/2010 5:26 pm
see last paragraph for aftermarket crown race
http://www.hopegb.com/voir_HSX.html
Posted : 27/09/2010 7:10 pm
Thanks 🙂 Any one know where you can buy one?
Posted : 27/09/2010 8:18 pm
Bump 🙂
Posted : 27/09/2010 10:11 pm
