What grease in a pr...
[Closed] What grease in a pro 2 evo free hub?
Whats the best grease to use in the freehub pawls/springs?
Posted : 06/11/2013 1:02 pm
I use CV grease from Halfords.
Posted : 06/11/2013 1:04 pm
I use a small amount of white lithium grease where they slot into the freehub body. It's not very tacky so doesn't slow down their operation.
Posted : 06/11/2013 1:05 pm
Comes with Mobil 222 as standard, it's an EP (extreme pressure)grease, ideally use something with a similar rating.
Posted : 06/11/2013 6:57 pm
Anything really, as above just don't use too much to stop the pawls from engaging. I actually find a good squirt of float fluid is just as good and the re-engagement feels crisper.
Posted : 06/11/2013 7:01 pm
This...but then float fluid is gear oil which is good stuff to use.
Posted : 06/11/2013 8:23 pm
watching this with interest
Posted : 06/11/2013 11:11 pm
My latest pro 2 sounds a lot quieter than my first (hope hoops v JRA builds), and I presume this is due to the amount of grease used? Taking them apart, there certainly seemed more Grease in the pawls of the former if not the ratchets.
Posted : 06/11/2013 11:34 pm
Most grease gets too thick and sticky when it's freezing cold hence the reason to use gear oil
Posted : 07/11/2013 7:45 am
I have a pot if red Pace grease I use in mine
Posted : 07/11/2013 8:02 am
quieter is due to revised springs
Posted : 07/11/2013 8:11 am
I've been using Float Fluid in my Hope XC and it definitely has better pickup and less slipping. Its been in there for about 4 or 5 months. Must have look at it and see how much is still in there.
Posted : 07/11/2013 9:11 am
I use marine pump grease, make sthem silent and doesnt stick up the pawls, even when below zero.
Posted : 07/11/2013 9:17 am
I use oil as I prefer it quieter and I've had sticky/freezing issues with grease. Only downside with oil is it needs re-done more frequently, but the noise tells you when to do it and its a quick easy job if you have the tools to whip the cassette off.
Posted : 07/11/2013 9:43 am
I used a wee bit of slick honey last time, seems to quiet it a little without causing any engagement issues.
Posted : 07/11/2013 10:05 am
