What Forks should I...
[Closed] What Forks should I think about
[#374793]
I am looking to replace the Fox TALAS forks on my 2004 Spesh enduro.
What models do you guys think it is worth me looking at.
I am considering moving up to 140mm as I don't think this will have to much impact on the geometery. But also looking to maintain the travel ajustability. So what's out there?
Thanks in advance for the ideas.
Posted : 09/03/2009 4:37 pm
You could try RC41 Fighters - similar axle to crown height but 10mm more travel...
Posted : 09/03/2009 4:42 pm
09 revelations, great forks and pretty light too
Posted : 09/03/2009 4:44 pm
I have the 09 Fox TALAS RL on my Scott Genius, they are superb. They have 150mm travel, adjustable from 110-130-150, with rebound adjust and lockout. I have coil sprung Revelations on my hardtail and thought they were good…but the TALAS are immense. I use the travel adjust all the time, whack it down to 110 for a climb, 130 for the less intense decents and 150 for that buttery smooth feeling that makes easy work of any trail
Posted : 09/03/2009 5:06 pm
You could try Coil Pikes...like mine.
Best forks I've ever ridden on.
You'd need a new hub though if your on Q/R at them moment.
Being somewhat rotund I like the extra rigidity the bolt-thru affords.
Were I not of the aforementioned rotund shape I'd probably run some of the new 140mm Rev's.
I don't tend to move the travel on mine much, usually between 130mm & 140mm, mine have a remote lock-out which I use a fair bit though.
Have to say that you do notice the difference when running at 140mm, steering is just a little slower & the bike settles into its rear travel a bit more. It certainly feels more confident on more technical / steep trails. These forks really saved my ass in Derbyshire recently when I hit a babies-head sized rocky section while trying in vain to catch 2 chaps on Orange 5's.
My 04'...
[img] ?v=0[/img]
Posted : 09/03/2009 5:14 pm
Love my 09 Talas 140mm - and they are fairly light and feel pretty rigid even with std QR's 😉
Posted : 09/03/2009 5:26 pm
Takisawa2 - it's a simple conversion on the exisiting hub if it's a QR Pro II, isn't it?
Posted : 09/03/2009 5:29 pm
Takisawa2 - my hardrock frame is still on offer if you want it?
Posted : 09/03/2009 5:30 pm
Thanks for the replies guys, some food for thought - off to check bank balance 🙁
Posted : 09/03/2009 6:01 pm
ononeorange...yes, a doddle. Thats what I'm running.
Posted : 10/03/2009 12:05 am
Anything you didn't like about the existing Talas.. if its just time for a new fork, then a new Talas will be better.
Posted : 10/03/2009 12:53 am
I recommend Pikes on an 04 Enduro, the bike just eats up bumps now and it's completely transformed it. The front end feels a lot stiffer too, partly down to the Maxle and partly down to the appalling Skraxle it replaced that Specialized insist on using in their hubs.
Posted : 10/03/2009 1:09 am
