What forks for a 20...
[Closed] What forks for a 2008 Cotic soul?
[#1614311]
Just got my nice new (to me) Soul frame from a lovely guy off here.
the current frame takes 140mm forks, but am I right in thinking the 2008 was only 130mm?
I'm trying to decide on forks for the frame, will it be bad if I put 140mm forks on it? I know geometry will change, but will I be in danger of breaking the frame?
I was thinking of Vanillas or maybe a Talas would be even better if I could find a cheap one, but should I consider anything else? Current models all seem to be too long travel for this frame though.
Thanks
Posted : 16/05/2010 10:11 pm
Pikes on mine, run at 125mm ish. 2007 model
140mm on the odd occasion
Posted : 16/05/2010 10:16 pm
mmm looks nice 😉 Love that mustard? colour, I'm a little sad mine is black, but actually its looking rather nice really.
I'm itching for longer travel, but don't want to break anything
Posted : 16/05/2010 10:24 pm
 bol
I've got the same issue with my Soda, which has the same geometry. I'm running rev u-turns on it at the moment (not going above 130), which are great, although I wish they'd wind down below 120. That said it is very nice at 120 and climbs well. I wish you could alter the range of travel adjustment.
Yes thats what I was thinking. If I went for recent (ish) talas forks they are 140-120-100 which means I would be wasting the longest setting and 20mm of travel.
Posted : 16/05/2010 10:33 pm
 bol
There's a good deal on dt Swiss 130s on CRC, but they're only 130 or locked down to 100. Bling though.
Posted : 16/05/2010 10:43 pm
 mboy
What forks for a 2008 Soul?
ANYTHING with between 100 and 130mm of travel, as that what they were designed to run!
Personal preference as to what you choose... 😉
Though personally, I'd go for some Rockshox Revelations myself.
Posted : 16/05/2010 10:44 pm
Ah thanks mboy, that was the answer to the question I was looking for. So it is designed for up to 130mm. Thanks
Thats a good find on the DT swiss forks, I don't know many people running them, is that and expense thing, or are there other problems with them?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=33724 ]These[/url] are looking like a really good choice for me at the moment though ... hmm
Posted : 16/05/2010 10:59 pm
 bol
Yep, they're the ones. I'm tempted too, but couldn't find anyone on here who could share a first hand experience of them. The other thing that nags me is how sweet it handles at 120, which I'd miss.
Posted : 16/05/2010 11:03 pm
Can you use launch control to set them to 120 (ish) or doesn't it work like that?
Posted : 16/05/2010 11:14 pm
 bol
I don't think so, but that was what I wanted to find out.
Posted : 16/05/2010 11:16 pm
 cy
What they've all said, but really, don't run forks longer than 130mm. The head tube/down tube junction isn't designed for anything more. The 2010 frames are considerably beefed up in this area for good reason.
Posted : 17/05/2010 2:40 pm
Thanks for confirming that Cy,
loving the look of my new soul, can't wait to get it together to start riding on it.
i've been giving it a lot of thought, and i think mboys suggestion is on the money, RS revelations with Uturn, run at 120, dial out to 130 if needed and down to 100 for the hills.
now I just need to find some in my (diminishing) budget.
Posted : 17/05/2010 4:56 pm
I put some rigid 440mm forks on my (2005 model) Soul. It handles superbly.
I know this won't help, but neither do the noodly Marz MXs I have on there the rest of the time.
Posted : 17/05/2010 5:10 pm
Yup, the 100-130mm Revelations are pretty much a perfect match... Light-ish, strong-ish, and there's something really satisfying about a u-turn that does exactly the range the frame's designed for.
I did run mine with 140mm for a while and it didn't snap, but then I'm a 10 stone mincer. In the end I concluded that if I ever did ride hard enough to justify the extra fork, I'd probably break it so went back to 130mm, which it does very well indeed.
Posted : 17/05/2010 5:12 pm
