What does you bike ...
[Closed] What does you bike really weigh???
I have an 07 Heckler in large. Annodized (that could make a difference compared to powdercoat) with a set of lyriks (coil u turn), DHX 5 coil with ti spring. XT/X9 kit. Thomson stem and post. Super wide bars and code brakes 8" disls on ex729/hope pro II wheels 2.5 tyres and DH tubes. Weighs in at 30lbs, using [img] [/img]
Posted : 17/02/2009 4:26 pm
pace 405 28.5 lbs wouldnt really want it mush lighter although i could still lose a lot from the wheels maybe go tubeless
Posted : 17/02/2009 4:37 pm
Medium Yeti 575 with the carbon seatstays, Revs, XT, Mavic 618's, Bonty Jones ACX and a fair bit of dried on mud: 27.4lbs
Posted : 17/02/2009 4:49 pm
My Patriot is 38 lbs with 2.4 maxis advantage tires, lyric coil forks, XT group set and hope wheel brake set, my 456 is 31 lbs with 2.1 conti diesel tires and magura durin fork, magura louise brakes, mixture of X0 and X9 with middleburn cranks and rings. I can survive just as big and long a day on both, unless there is lots of very steep techy climbing, then I last longer on the 456. Which I put down to the differing geometry of both bikes.
However....... considering that my camelback, filled for a long day with tool kit, spare inner tube, 2 or 3 snack bars plus sarnies, pump and shock pump, 2 or 3 litres of water and camera weighs at least 9 lbs, and add my 195 lbs then I feel the difference is moot.
Posted : 17/02/2009 5:48 pm
Dialled PA- 29lbs on bathroom scales
Merlin Malt1 singlespeed - 25lbs
Posted : 17/02/2009 6:37 pm
 rs
I just stripped my Enduro frame in preparation for my alpine arriving figured it would be a good opportunity to weigh everything on the digital kitchen scales so for anyone thats interested, this is what all these bits weigh. Its all pretty good kit and there's not really anywhere I want to go much lighter. (formating doesn't work too well everything is in nice neat columns in the edit window, bah!)
Frame Dialled Bikes Alpine (guess for now) 2500g 5.51lbs
Fork Rock Shox Pike 426 2435 5.37
Headset ??? 200 0.44
Saddle SDG Bel Air Titanium 284 0.63
Seatpost Chromag Minimalist 27.2 x 410 240 0.53
Seat Collar Chromag Brass 80 0.18
Handlebar Sunline V1 277 0.61
Stem Thomson Elite X4 176 0.39
Grips Lock-on with straitline end caps 128 0.28
Pedals DMR V12 Mag 444 0.98
Bottom Bracket Hone 96 0.21
Cranks Hone Non-Drive Side Crank Arm 228 0.50
Cranks Hone Drive Side Crank Arm 395 0.87
Cranks Hone Middle Ring 43 0.09
Cranks Straitline Bash Guard 123 0.27
Cranks 4 Crank Bolts 12 0.03
Chain SRAM PC 971 286 0.63
cassette Shimano XT 295 0.65
Rear Mech SRAM X9 235 0.52
Rear Shifter SRAM X7 200 0.44
front wheel Sun SOS Rim on Spesh Stout 20mm Hub 942 2.08
front tire Maxxis High Roller 2.35 ST 830 1.83
front tube ???? 200 0.44
front rotor Aztec 203mm 200 0.44
rear wheel Sun SOS Rim on Shimano Hub 1150 2.54
rear tire Maxxis High Roller 2.35 ST 830 1.83
rear tube ???? 200 0.44
rear rotor Aztec 203mm 200 0.44
Front Brake Avid Juicy 3 260 0.57
Rear Brake Avid Juicy 3 335 0.74
Whole Bike 13824 30.48
spreadsheet here
[url] http://spreadsheets.google.com/ccc?key=pARYVlzv7VbFYhtYumz1Lcw [/url]
Posted : 17/02/2009 6:52 pm
21 lbs in race mode (717wheels 1.95 tyres etc)
22-23 lbs trail fat tyre mode and hell of a lot more comfortable.
2 separate LBS's weighed it.
Carbon and full XTR.
Did it make a difference? hell no. Did it make me enjoy or go faster? Nope!
What did? me getting fit and losing 20kg of fat from riding my heavy road bike.
Building a 28 lbs heavy old single speed. -It's fun handling frame! If I was really worriefd about weight I'd buy another carbon Zaskar etc.
I'd rather ride a Genesis or Kona Extreme Cro mo just for the ride quality.
So best weight weenie was not to be a fat b&stard. Now I'm a slim b&stard.
Pass me some apple pie-it's my fetish/kryptonite 😈
Posted : 17/02/2009 6:59 pm
My "over biked" Nomad 32.5lbs, which seems the same or only slightly heavier than some peoples "under biked" hardtails, hmmm...
Posted : 17/02/2009 7:15 pm
Page 4 / 4
