What chainring do I...
[Closed] What chainring do I need? (And why is this so complicated?)
[#11057103]
Need to replace a boost SLX barrow wide chainring. Thought this would be easy, but why is it so difficult?
Looking at Works Components and Superstar, but nothing is self explanatory. It either doesn’t say boost or it has some other weird terminology that makes me wonder whether it’s going to fit.
So, please help - setup is 1x11 boost SLX. What chainring from either of the above do I need?
Cheers,
JP
Posted : 19/02/2020 11:47 pm
If it is shimano boost crank then the boostiness is in the spider so you just need a standard chainring of the appropriate bcd. (96 bcd for m7000 slx I think).
Edit - like this one https://www.superstarcomponents.com/en/raptor-chainring-96bcd-asymetric--narrow-wide.htm
Posted : 20/02/2020 12:00 am
Cheers. I was finding it hard to work out where the boost element is - some info on the web says it’s the cranks, others the chainring. I guess it’s different for different brands?
JP
Posted : 20/02/2020 12:08 am
With SRAM it's the chainrings. With Shimano it's the cranks. Not usually worth getting het up about unless you have chainring/chainstay clearance issues.
Posted : 20/02/2020 2:06 am
I shopped around and eventually just went for a Shimano one! It is actually a perfectly functional component and the composite construction on the SLX is pretty clever!
Posted : 20/02/2020 6:07 pm
Yeah - you might be right. Will these work with XT 12 speed if I upgrade?
JP
Posted : 20/02/2020 7:41 pm
