What bodge to patch...
[Closed] What bodge to patch a tubeless tyre?
I don't want to wait till patches come through the post. Any ideas of a quick fix?
Posted : 20/04/2016 1:25 pm
 Yak
bit of innertube and impact adhesive.
*you may die though, but it worked for me in a similar situation. Still stuck on fine after a year.
Posted : 20/04/2016 1:28 pm
My Chronicle 3.0'' got a rip from some flint.
I used a puncture repair kit- sandpaper to key the area and then stuck the batch on. Done! Never been an issue.
Posted : 20/04/2016 1:40 pm
I've used an inner tube patch inside the tyre many a time, haven't died yet (though I know I will). Have heard you can use a bit of elastic band in place of a tyre worm but never tried it
I've used a tyre boot and a bit of epoxy on a sidewall split and it worked fine, same as putting an inner tube patch on the inside. I figure that even if the patch fails, the hole is small enough it won't be catastrophic.
Posted : 20/04/2016 2:11 pm
Just used a run of the mill puncture patch and glue like what you would use on a tube. Seems to be holding at the moment. Haven't actually used that bike yet though, so it'll probably end in tears.
Posted : 20/04/2016 2:42 pm
Use a normal patch superglued to the inside of the tyre. I've done that 5 or 6 times now and I haven't had any of them fail yet and that's with months of further riding. I wouldn't bother buying any specific tubeless repair stuff.
Posted : 21/04/2016 11:27 am
This bit of rubber band has been in there for 6 months.
[URL= http://i1097.photobucket.com/albums/g341/kiwijohn42/7FDA89CE-1E19-4623-93FA-B9E314976E82_zpslxel9vfo.jp g" target="_blank">http://i1097.photobucket.com/albums/g341/kiwijohn42/7FDA89CE-1E19-4623-93FA-B9E314976E82_zpslxel9vfo.jp g"/> [/IMG][/URL]
Posted : 21/04/2016 11:35 am
Most of my tyres have normal puncture repair patches in them,one actually has 3! Oldest is about a year old and working fine. Just don't sand the inside of the tyrw, clean with IPA instead
I've got a tyre on an old knockabout bike that I patched with duct tape during the 2007 Megavalanche and it still goes up tubeless.
Posted : 21/04/2016 12:13 pm
