What 820mm Bars Are...
[Closed] What 820mm Bars Are Available?
[#10479685]
I have found the 35mm Spank Spike but its only available in 25mm rise.
What else are STW aware of?
Posted : 09/02/2019 7:11 pm
Think RaceFace do.
Posted : 09/02/2019 7:18 pm
Leftfield option - the 800mm bar of your choice with a pair of Deathgrips.
They've taken my 780mm bar to pretty much 800mm.
unless you were using a single bolt lock-on grip anyway, of course.
Posted : 09/02/2019 7:36 pm
Do superstar still do the yardstick?
Posted : 09/02/2019 7:41 pm
I think Bontrager did a few. Line 35 I'm sure.
Posted : 09/02/2019 8:26 pm
Yep the Bontrager carbon car is. I had to cut mine down to 800 ha....
Posted : 10/02/2019 6:44 am
My Whisky bars are 840. Although chosen for back sweep rather than width.
Posted : 10/02/2019 8:34 am
“Leftfield option – the 800mm bar of your choice with a pair of Deathgrips.
They’ve taken my 780mm bar to pretty much 800mm.”
They do add width but only 5mm each side, 10mm total - unless you’ve failed to hammer them on all the way!
RaceFace do a few 820mm bars, with up to 35mm rise.
Posted : 10/02/2019 9:43 am
Most RaceFace bars are 780-800 but there's this one:
https://www.raceface.com/products/details/sixc-35-820mm
Posted : 10/02/2019 10:08 am
I’m running Spank Spike vibrocore 31.6 bars with 50mm rise.
I was using Santacruz Palmdale grips that gave me an extra 5mm per side like the deathgrips but I have switched to Oury lock-ons whicch clamp at both ends.
I think if you are quite big 800mm is a bit narrow.
Posted : 10/02/2019 1:22 pm
