Wet or Dry?
[Closed] Wet or Dry?
[#3614603]
Which lube is best? And why.
Posted : 27/01/2012 1:32 pm
is it wet or dry out?
Posted : 27/01/2012 1:33 pm
could be either
Posted : 27/01/2012 1:34 pm
 ton
wet for winter
dry for not winter
Posted : 27/01/2012 1:35 pm
I've found Pedros Ice Wax ok for shortish rides in mildly wet conditions but you do need to dry chain quick when you get in as the wax tends to wash off and the chain rusts, if it's proper wet and you'll be out for a while then a wet lube (I like the muc-off one) is best.
Posted : 27/01/2012 1:36 pm
i use wet all year round now. Used to use wet or dry depending on the season / conditions. Probably still advisable in dusty conditions.
Posted : 27/01/2012 2:56 pm
Wet for the uk. Dry is great if it's not raining every **** day for months on end.
Posted : 27/01/2012 2:58 pm
I pretty much just use wet, and apply it more sparingly in the summer.
Posted : 27/01/2012 3:21 pm
Progold Prolink all year. It's kind of like a wet dry lube.
Posted : 27/01/2012 3:22 pm
