Weather proofing yo...
[Closed] Weather proofing your bike tips?
[#2926175]
I planning to write an article on routing servicing bikes (general things to consider) and also winter proofing you bike. I have got my article in draft but wondered if anyone had any tips I could add:
Things like: Sealing the seat tube, sealed/full outers, greasing? Just in case I have left anything obvious out?
Many thanks
FXR
Posted : 08/07/2011 12:16 pm
Alfine 8)
Posted : 08/07/2011 12:17 pm
Alfine? Nah, singlespeed 🙂
Posted : 08/07/2011 12:18 pm
singlespeed, clean and oil the chain
oh and maybe wave a hose at it every once and a while
[edit] beaten to it 😉
Posted : 08/07/2011 12:20 pm
I leave mine in the garage and use a car.
mibbe wash it once a year and lube the chain every now and then..
Posted : 08/07/2011 12:21 pm
I'm trying not to be sarcastic, but why would any of that be WINTER proofing?
At the moment outside it is hammering down with rain. I might ride later but my bike isn't winter proofed. What should I do?
Seriously, in the winter the mud and rain are just a bit colder - why would that bother my bike?
EDIT: YOu are going to be stuffed on TransWales if you think August is summertime in Wales! 😉
Posted : 08/07/2011 12:27 pm
move to somewhere with a real summer?
Posted : 08/07/2011 12:29 pm
Scottoiler
 fbk
You didn't expect serious answers on here did you? 🙄
Posted : 08/07/2011 12:31 pm
WOW - what a response. Many thanks. Never mind.....
BTW - why does everyone think that the way they have their bike set-up is the same as everyone else?
This is the one reason I rarely post up a thread on this forum these days!
Posted : 08/07/2011 12:37 pm
I stretch sections of inner tube over the headset and the seat clamp to keep the weather out of the frame.
Posted : 08/07/2011 12:40 pm
My bike has suffered more crud'n'crap so far this summer than all of last winter 😕
I don't really see what winterising is other than keeping the crud catchers on as the default setting and changing from 'wet' to 'even wetter' chain lube.
Posted : 08/07/2011 12:42 pm
 grum
[b]I planning[/b] to write an article on [b]routing[/b] servicing bikes
Not sure about winter proofing but I'd make sure you get someone to proof read your article. 😛
Cheers Jack 🙂
Posted : 08/07/2011 12:43 pm
A lot of stuff is opinion not fact.
My top 2 tips - buy a cable oiler and use putoline chain wax on the chain.
Posted : 08/07/2011 12:45 pm
middleburn oilers if you have gears.
if you are anticipating riding through an increased number of streams thicker grease on any cup and cone bearings.
Make sure any aluminium seat posts in steel frames have a good dollop of anti-seize on them (galvanic corrosion).
if your cartridge bearing need replacing consider SKF
Posted : 08/07/2011 12:52 pm
Many thanks Brick - good points
Posted : 08/07/2011 12:54 pm
Electrical tape (it's got a bit of stretch) over seatpost slot, below clamp.
Midleburn cable oilers.
mud guards.
APF
Posted : 08/07/2011 1:03 pm
Hi Foxy,
I wouldn't do a great deal tbh, i'd consider the following at anytime of year, so I guess this is stuff I'd do over and above usual:
Use a wet weather lube on chain
If my bike suffered from crap cable routing I'd think about continuous outers, but its done fine so far...
If its really wet and slippery I generally drop my saddle by a fraction for better control.
Give the bike a good clean regularly and wipe down with WD40 - it stops mud sticking so easily (and smells good).
Check drainage holes are free/not blocked.
Tyre pressures...maybe.
TBH though, its a mountain bike, I figure it'll cope with most things better than I will.
HTH
Posted : 08/07/2011 1:04 pm
They don't, they think they have them set up [b]better[/b] than everyone else.
To prove the point I laugh at your singlespeeds and alfines and use the Rohloff when it's a bit grim out. 🙂
Posted : 08/07/2011 1:07 pm
Cheers Matt - of course, just wanted to see if I had not come across or forgotten any useful tips to minimise wear and tear esp on long rides etc
Posted : 08/07/2011 1:11 pm
Ha, I laugh at your gearless throwback bikes and 2kg rear wheels as I can keep proper bicycle gears running smoothly in winter conditions 😛
Posted : 08/07/2011 3:24 pm
Turbo trainer and tv = weather proof but not the same serotonin kick...
I spray my frame in GT 85, let dry so when it gets really muddy I find it is easier to wash.
Rest of the bike? service once a month on my day off. A light weight tough alfine would be awesome but so would a one way ticket to Australia.
Posted : 08/07/2011 3:28 pm
Cleaning and drying the bike after a wet ride works for me. With new (to me) frames I always drill a nice big hole for drainage under the BB.
Posted : 08/07/2011 3:32 pm
weather/winterproofing here just consists of cleaning/drying the bike off after a ride and giving bits like cables/Mechs a squirt of gt85 or similar
Just keeping an eye on things as well.. when I'm cleaning it I have a quick look at the brake pads to see how much is left, and you know if you're getting drivetrain problems 'cause it'll already have happened on the ride!
Posted : 08/07/2011 4:21 pm
I split my sides at the thought of you cleaning your gears while I sit inside with a lovely cup of Earl Grey. 🙂
Posted : 08/07/2011 4:38 pm
