Warrantied Pikes, a...
[Closed] Warrantied Pikes, and Diamonds... try the 36's now!?
I bought Pikes, because they get good reviews and are about half the price of the alternatives.
They developed a CSU creak, and were warrantied
Decided to try something different, and really liked the sound of the OTT feature on the diamonds.
They have a clicking/rattle in the first few mm of travel, and have been told that's not normal, send back for refund or replacement..
In the 2 rides I had on them, they are either better or I convinced myself that they were better than the Pike, the OTT does seem to do what it says on the tin...
Do I give them another go, or try 36's I'm a bit concerned over reports of harshness from the 36's when your not going race pace and just having a easy ride...
oh no, not another #whatenduroforkformy#soendurobike!!!
Posted : 24/11/2015 10:22 am
I suggest a bit of Google.
It's quite a well documented issue that there is no fix for.
Posted : 24/11/2015 11:05 am
Bos or Manitou.
Unless you're rolling on 29s like me, in which case I think I'd go with the 36s.
Posted : 24/11/2015 11:08 am
MRP Stage
Posted : 24/11/2015 11:15 am
get the 36's if you can.
they take a bit of setting up and bedding in (volume spacers and damping tweaks) but once there, they track better than any other single crown fork i've ever used and once bedded in are as plush as anything else out there, depending on how you've got them setup.
only thing is volume spacers are hard to get from Mojo as they rarely seem to have stock.
Just bear in mind they also can have a rattle, this is a check valve and is replaceable under warranty (had mine done and been perfect ever since over 8 months of use) no big deal.
Posted : 24/11/2015 11:18 am
Yeah, Ive read about this as a "known" issue, I emailed DVO and spoke to the shop.
DVO never replied, the shop said that it could cause problems and send them back, don't continue to ride them.
As soon as the shop say that, if i had further problems down the line they might not honor the warranty was my concern.
sounds really quite bad -
Posted : 24/11/2015 11:27 am
 Dan
That sounds like the negative spring has become unseated - check out the travel adjustment video on the dvo website to see what I mean. It shouldn't happen by itself of course ...
Posted : 28/11/2015 7:09 pm
I have the new 36 and they are amazing. Far better than any of the pikes I have had which in honesty I have never liked. They always feel a bit cheap and over hyped. I haven't even adjusted the settings on the 36 and they feel so good I may not bother.
Posted : 28/11/2015 7:26 pm
Had a pair of dvo's since March! Had nothing but issues from the start
First the topping out issue which seems to be a commen problem
Sent them back and got this sorted......for a few weeks.....then the fork developed a very annoying rattle as if the damper was loose or as mentioned before the negative Spring!! Took them apart and all seemed OK.
After phoning silverfish and getting fobbed of a number of times finally got somewhere and they fitted a new upgraded OTT unit.
Apparently they have had a massive batch from dvo to cure the problem, so any of you guys with issues give them a call and kick up a fuss!
A fork of this price and quality shouldn't be as **** as they are!
Now mine are back I must say they feel amazing!!
Posted : 28/11/2015 10:18 pm
Loving my MRP Stage.
Posted : 28/11/2015 10:42 pm
Happy 'new style' 36 user here.
Posted : 29/11/2015 7:34 am
This comment would suggest that you're not going to notice the difference between any of those forks. They're all good, and unless you're smashing descents, your decision should be based on price, looks and colour.
Posted : 29/11/2015 11:18 am
Seems like a bit of an obtuse comment...
He forks will go on a bike that will do uplift days, happy enough on the blacks at stiniog, will be raced, and will go out on big multi hour days...
theres a thread on mtbr where lots of people have complained about them feeling very harsh, so doesn't seem an unreasonable concern on a bike that isn't going to only going to be a race or uplift bike...
for what it's worth I've ridden devilles, pikes, DVOs in this travel bracket, and can definitely tell the difference between them.
Posted : 29/11/2015 12:10 pm
 mboy
Another recommendation for the MRP Stage here
Had one on my bike for 6 months now, it's been faultless. Had a Pike previously, but even with plenty of tokens in I could never get it set the way I liked. By contrast the Stage is more supple, has much better ramp up control that you can adjust on the fly, and it's easier and cheaper (the spacers come in the box) to adjust the travel should you need to. The Stage is also a little shorter axle to crown than the Pike, so you can run it 10mm longer travel for a similar ride height, and the axle is so quick and intuitive to use. The service intervals are a relatively bonkers 200hrs too, which means an average rider actually might get near enough a season between services unlike some other makes!
Posted : 29/11/2015 1:00 pm
You've elaborated now ๐Ÿ˜‰
You're gonna want to be able to adjust high and low speed compression damping, and adjust volume if you're doing that range of riding.
Generally I'd be aiming for a fork that'll work very well at the extreme of use, as if its a little harsh on bumbly stuff it doesn't matter, but if it can't take big hits on an Uplift day, then that's a real PITA.
I'm surprised with the Fox 36 comments, as its by far the plushest fork I've ridden. And you can manually adjust the compression damping, so if its harsh, you can do something about it.
Have you considered the Lyric?
Posted : 29/11/2015 1:06 pm
I'll throw a curveball into the mix.....have you thought about Marzocchi 350CRs or 350NCRs.
I've got some 350CRs, and after a bit of bedding in they are displaying that famous Marzocchi plushness. A bit simple on the adjustment features side, but IMO that is generally to the good. Travel adjustment is by internal spacers (140/150/160) and the CR adjustment works well for stopping diving on the climbs.
8/9 months use so far and they have been excellent.
Posted : 29/11/2015 4:42 pm
 Dan
thanks for the heads up about the ott upgrade rcr1303, a cure to the noisy chatter from these forks is really news
Posted : 29/11/2015 7:27 pm
If you're happy spending money on further upgrades when service time comes the Push kit for the newer 36s smooths out the slight high speed compression kick. It really wasn't much of an issue anyway IMO I just wanted to see what the difference was.
Posted : 29/11/2015 9:55 pm
I've said on here about my 36's (2016 fork) being just a bit nasty. Good for racing, not so good for normal riding (which is 95% of the time in reality).
Also, possibly the most unreliable fork i've ever owned.
That said, I wouldn't have a DVO. There are a couple of them in my extended riding group - both bitching about the rattle & they look like they were painted by Stevie Wonder & his masonry brush. I've done better rattle can jobs myself in the past.
Posted : 30/11/2015 9:57 am
I decided to give them another go, as figured i don't have anything to lose really as the shop has been really good about replacing them.
If I have the same problem with the next pair I'll have a look inside them myself at the negative spring and try to resolve, if there is still bother then I think I'll be going down the 36 route.
Posted : 30/11/2015 11:50 am
That's weird as the shop reports I've heard are that theyve got an incredibly low failure rate.
Maybe they're just ridden by numpties ๐Ÿ™‚
Posted : 30/11/2015 4:35 pm
A shop that's trying to sell you something?
To be fair, you do t hear many reported issues, but 3 full rebuilds in about 5 months of use in my experience = dogturd reliability. IMO it's no better than any of the older RC2 forks. Fox just don't seem to be able to make a fork that's supple in its initial stroke, that then doesn't blow through the rest of its travel far too easily.
Of other forks I've ridden, the Pike, Lyrik & Deville are all more supple. The latter two have much better mid stroke support and bottom out IMO. The Pike mostly feels better than the 36 apart from at the limit, when it gets a bit overwhelmed.
I'm definitely a numpty though.
Posted : 30/11/2015 6:13 pm
