Using triple shifte...
[Closed] Using triple shifter with double mech - how?
I've got a perfectly serviceable x9 shifter but am going to use it with a double chainset and mech. Any good way to do this?
Posted : 25/04/2014 7:21 am
Connect the cable, set up the same?
Posted : 25/04/2014 7:23 am
Wind in the upper limit screw, so it can't go past the middle (outer) ring?
Posted : 25/04/2014 7:28 am
It's a triple shifter though which two of the gears do I set up and which do I leave out?
I just used to set the lowest gear on the shifter as the lowest on the mech. Your limit screw up top should stop it over shifting.
Posted : 25/04/2014 7:29 am
*I think* that the shift from middle to big ring is more suited to a double than the granny to middle. I have no idea why other than I read it on here somewhere in relation to the little switch thing that shimano use to turn triple shifters into doubles.
[hijack]
triple shifter
triple mech
double chainset
Will it work?
[/hijack]
Posted : 25/04/2014 7:32 am
