Using OS Maps SD Ca...
[Closed] Using OS Maps SD Card With Edge 810 - Help Needed
Hi all. I have a Garmin Edge 800 with an SD card for OS maps on it. Does anyone know if the OS maps will work if I put the SD card into an Edge 810, or is the SD card tied to the Garmin you use it with via some DRM or licensing somehow?
Thanks in advance!
Posted : 17/06/2013 8:49 am
